Kinematics problem but no numbers given?
48 replies · 18K views · last reply
That just means that the drag racer waits until he knows the car will just miss his bumper at the later time t = t_max. So when the dragster starts off there is a certain distance (i.e. d_start) between him and the car. If he started just before the car hit him then there would definitely be a crash unless the dragser could accelerate almost instantly.
ok... but since it's a distance, not a vector, it shouldn't have a negative sign for the answer... and when I plug in the givens to d = 1/2at^2 - v1t, I get a negative answer... ;;
From the way the question is set up it is in the negative x direction if you like. To make it work in the equations it must have a minus sign that is.
so practically, i found the displacement...
a distance can't have a negative sign, right? is there a way to cancel it out somehow?? because it says in the question that the answer for the distance should never be negative.
so... if v = 25m/s and a = 50m/s^2..
i get a negative answer...
but just write it as a positive?!
just changing the negative answer to a positive answer is allowed?!
What you're doing is finding the magnitude of a vector, except since this is 1D the magnitude will be [itex]\sqrt{-s_0^2}[/itex].
ummm.. kurdt?
big problem here...
after all this work, the computer says tmax does not equal v/a...
it says that it doesn't depend on the variable, v...
what do i do? T.T
maybe technical error? should it be v0?
It should certainly depend on the speed of the car.
ok technical mistake whew!
i had to write v_0 / a
now... for dstart... since this is really sensitive about technicality...
i shoud write dstart = 1/2atmax^2 -v_0tmax right? not just t?
I don't know the system but write whatever you think it will accept. :smile:
i wrote d_start = 1/2at_max^2 - v_0t_max...
and it says it contains an incorrect multiplier or is missing one... huh?!
I have no experience with these things. I used to hand in bits of paper with squiggles on. I suggest seeing if the thing has a FAQ or is there anyone around that you can ask for advice? A tutor maybe.
so you don't think there's anything wrong with the equation, just physics wise?
Kurdt said:
No it looks fine.
soo... according to our teacher, there may be something wrong with the equation itself..T.T
not the way I input it...
he said I'm figuring out "your distance from the dragster when he started". and that i shouldn't forget the additional point
made in this question about assuming that the dragster starts at x=0 when t=0.
I honestly can't figure out what's wrong...
why would it say incorrect multiplier or is missing one?? grr what is wrong with this equation??
Well that's exactly what you have done and is the reason that extra distance term appears in the cars distance equation. I'm just thinking the distance equation for the car might have to subtract the the distance since it starts behind the dragster and the direction they travel in is defined positive.
I'm still not quite sure how to change the equation to make it right..
subtract which distance?
ahhh i don't get it...!
