Kinetic Energy in Rotational Motion Problem
The discussion revolves around calculating the rotational kinetic energy of a flywheel shaped as a uniform solid disk with a radius of 1.30 m and mass of 72.0 kg. The maximum radial acceleration allowed is 3600 m/s², leading to an angular velocity of 52.6 rad/s. The moment of inertia is calculated as 122 kg·m², resulting in a computed kinetic energy of 1.68 x 10^5 J. However, the correct kinetic energy is 8.42 x 10^4 J, highlighting the importance of the factor (1/2) in the rotational kinetic energy formula, K = (1/2)Iω².
  • Understanding of rotational motion concepts
  • Familiarity with the moment of inertia for solid disks
  • Knowledge of angular velocity calculations
  • Proficiency in using the rotational kinetic energy formula
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the relationship between linear and angular acceleration
  • Explore advanced applications of rotational kinetic energy in engineering
  • Investigate the effects of radial acceleration limits on flywheel design
Students and professionals in physics, mechanical engineering, and anyone involved in the design and analysis of flywheels and rotational systems.
itsme24
Ok the problem is:
Energy is to be stored in a flywheel in the shape of a uniform solid disk with a radius of 1.30 m and a mass of 72.0 kg. To prevent structural failure of the flywheel, the maximum allowed radial acceleration of a point on its rim is 3600 m/s^2.
What I did was solve for the angular velocity through the radial acceleration:
3600m/s^2 = rw^2
w = 52.6 rad/s
Then I solved for the moment of inertia:
I = mr^2 = 72.0kg(1.30m)^2 = 122 kg*m^2
Finally I plugged it all into the rotational kinetic energy equation:
K = (1/2)(122m*m^2)(52.6rad/s)^2 = 1.68*10^5 J
The actual answer is 8.42*10^4, exactly half of what I got. I don't suppose someone could explain where the *(1/2) is coming from?
The moment of inertia of a disk is?
hehe (1/2)mr^2
Energy is to be stored in a flywheel in the shape of a uniform solid disk with a radius of = 1.16m and a mass of 73.0 kg. To prevent structural failure of the flywheel, the maximum allowed radial acceleration of a point on its rim is 3510 m/s^2.
CAN SOMEONE PLEASE SOLVE THIS FFS IVE TRIED SO MANY OPTIONS AND ITS NOT WORKING!@@!_#!@#!@!@#)!@(#*)!@(#)((!@*
  • · Replies 21 ·
  • · Replies 19 ·
