Kinetic energy involving angular momentum and inertia
The discussion focuses on the calculation of kinetic energy (KE) involving angular momentum and inertia in a system consisting of a rod and putty. The correct moment of inertia for the rod pivoting at one end is established as I=(1/3)ML², while the total kinetic energy after a perfectly inelastic collision is derived as KE=(5/6)MgL+(1/12)Mv². Key equations utilized include KE=(1/2)Iω² and L=Iω=MvR, with the parallel axis theorem being referenced for moment of inertia calculations. The conversation concludes with a clear understanding of energy conservation principles in the context of the system's motion.
  • Understanding of kinetic energy equations, specifically KE=(1/2)Iω² and KE=(1/2)Mv².
  • Familiarity with angular momentum concepts, particularly L=Iω.
  • Knowledge of moment of inertia calculations, including I=(1/3)ML² for rods pivoting at one end.
  • Application of the parallel axis theorem in rotational dynamics.
  • Study the derivation of the parallel axis theorem and its applications in rotational dynamics.
  • Explore the principles of energy conservation in inelastic collisions.
  • Investigate the relationship between linear and angular velocity in rotating systems.
  • Learn about the implications of torque and external forces on angular momentum conservation.
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors seeking to clarify concepts related to kinetic energy, angular momentum, and moment of inertia in rigid body dynamics.
penguinnnnnx5
Problem with diagram here
I=(1/3)MR2 (I believe the formula given in the problem is incorrect since it is pivoting on one end rather than the center of mass)
KE=(1/2)Iω2+(1/2)Mv2
L=Iω=MvR
a.
True, the velocity is still going in the same direction at the instant of the collision.
False, it is a perfectly inelastic collision, which means kinetic energy is not conserved.
True, no real reason why. I just think it's true? No forces seem to be working on the center of mass during the collision.
True, no external forces/torque are working on the collision at that moment.
b.
(M/3)Lv=(1/3)ML2ω+(M/3)ML2ω
(M/3)Lv=(2/3)ML2ω
v/(2L)=ω
c.
KE=(1/2)Mv2+(1/2)Icmω2
I have no idea how to approach this correctly other than the possible use of the parallel axis theorem. This was as far as I got
The answer is given: (5/6)MgL+(1/12)Mv2
Can someone please explain to me the steps to get to that answer?
L=Iω=MvR
These equations are valid only if you explain the meaning of the notations.
The formula for the moment of inertia is correct: I=1/12 ML2with respect to the CM. With respect to the pivot, it is 1/3ML2
penguinnnnnx5 said:
a.
No, the rod is not free to move, the force at the pivot acts during the collision, it can be of any magnitude, so can not be ignored.
That is right.
False, the change of angular momentum depends on the external torque. With respect of the CM, there is an external torque from the force at the pivot. The angular momentum of the whole system conserves, and its includes both the angular momentum of the rotation about the cm and the angular momentum of the cm orbiting about the pivot.
The angular momentum conserves with respect to the pivot, as the torque of the external force at the pivot is zero, and also the torque of gravity is zero with respect to the pivot.
penguinnnnnx5 said:
b.
(M/3)Lv=(2/3)ML2ω
v/(2L)=ω
Correct.
penguinnnnnx5 said:
c.
After the collision, the energy is conserved. When the rod starts to move, it has both kinetic and potential energy. What is its initial potential energy?
The KE of a rigid body rotating about a fixed axis is 1/2 Iω2. What is the moment of inertia of the system putty+rod with respect to the pivot?
ehild
ehild
I think the PE is:
PE=mgL
since the height fallen with respect to the putty and rod is the entire length of the rod.
As for the moment of inertia, is it:
I=(1/3)(M/2)L2 + (M/3)L2?
The mass of the rod being halved because not all of the rod's mass is (because I'm unable to think of a better word at the moment) "used"?
Or since the masses are combined now and are rotating about the pivot point
I=(1/3)(M/2 + M/3)L2?
penguinnnnnx5 said:
I think the PE is:
PE=mgL
consider the potential energy with respect to the ground. When the whole system fell down, it has zero PE. Initially, the putty had M/3 gL potential energy, but the PE of the rod was? ... The pieces of the rod are not at equal height, so the potential energy of a bottom piece is about zero and a top piece is at height L...
Why do you think that not all the mass of the rod is "used"?
The moment of inertia of the rod with respect to the pivot is (M/3)L2. The moment of inertia of the putty (of mass M/3) is (M/3) L2. The momenta add up.
ehild
ehild said:
consider the potential energy with respect to the ground. When the whole system fell down, it has zero PE. Initially, the putty had M/3 gL potential energy, but the PE of the rod was? ... The pieces of the rod are not at equal height, so the potential energy of a bottom piece is about zero and a top piece is at height L... Why do you think that not all the mass of the rod is "used"?
ehild
Oh I thought because not all the mass is at the far end of the rod, the mass should be halved. My mistake.
So Itot=(2/3)ML2
KE=(1/2)(2/3)ML2ω=(1/3)ML2ω=(1/3)MLv2
PE=(M/3)gL+MgL=(4/3)MgL
(1/3)MLv2=(4/3)MgL
v2=4g ?
Then do I plug this into the KE equation so it is
(1/3)ML4g=(4/3)MLg?
I think I figured out the (1/12)Mv2 portion as well. Could it be:
ω=v/2L
(M/3)(L2)(v2/4L2)=(1/12)Mv2 ?
ω has to be squared in the equation for the KE.
The potential energy of the rod is not mgL as not all the mass is at height L.
The potential energy of the rod is the same as if all its mass concentrated at the centre of mass.
ehild
ehild
So PE=(M/3)gL+Mg(L/2)=(5/6)MgL?
KE=PE
(1/3)MLv2=(5/6)MgL
v2=(5/2)g
ω=v/4L (from part b)
So KEf= (M/3)L2ω2+(M/3)L2(v2/4L2)
KEf=(1/3)ML(5/2)g+(1/12)Mv2=(5/6)MgL+(1/12)Mv2
Is that all right? If so, what happened to the (1/2) in front of both of the MLω2?
KE=PE
It is not true. After the collision, the system rod+putty has bot KE and PE.
At the final state, there is only KE.
ehild
ehild
Ahh! I see. I think I got it now! So once the rod falls all the way down, all the PE is transformed (is that the right word to use? I feel like it isn't.) into KE. So the we can just use PE for part of the final KE.
Then we also have the KE from the putty and rod during the collision, right? So it'd be:
(1/2)Iω2+(1/2)(M/3)L2ω2
=(1/2)(M/3)L2ω2+(1/2)(M/3)L2ω2
=(M/3)L2ω2
=(M/3)L2(v2/4L2)
=(1/12)Mv2
Yes?
Then you add them together to get
(5/6)MgL+(1/12)Mv2
Thank you so much for all your help! I can't believe I forgot about how PE turns into KE as the rod falls down... Thank you!
It is perfect... :smile:
And the solution is correct. Good job!
ehild
16K
  • · Replies 17 ·
  • · Replies 22 ·
