Kinetic/Potential/Mechanical Energy Problems
  • Thread starter Thread starter k0k
    Energy
11 replies · 5K views
k0k
A human "cannon ball" in the circus is shot at a speed of 21.0 m/s at an angle of 20 degrees above the horizontal from a platform that is 15.0m above the ground.
a. If the acrobat has a mass of 56.0 kg, what is his gravitational potential energy relative to the ground when he is at the highest point of his flight? Ignore the effects of air resistance. (Ans: 9.69X10^3 J)
b. If the net in which he lands is 2.00 m above the ground, how fast is he traveling when he hits it? (Ans: 26.4m/s)
[Ek=Kinetic Energy, Ep=Potential Energy, Em=Total Energy]
Ep=mgh
Ek=1/2mv^2
W=Fd
Em=Ep+Ek
I have found both the Ep and Ek values and added he values up, but the answer isn't anywhere near close. There is something more to it I believe, but I'm not even fully sure how Potiential energy and Kinetic energy are related. I have no idea whether the angle is relevant or not eithier. Explanations would be great help.
Help would be much appreciated. Thanks~
For a) It's the vertical component of initial velocity that makes sense.
[tex]0 - v_{0y}^2 = 2( - g)h_0[/tex]
with h0 is his highest reach relative to the 15-m platform.
Then the gravitational pe can be deduced easily
For b) You should also pay attention to the horizontal component [tex]v_{0x}[/tex]. It remains unchange during his flight
Now you need to find the vertical component [tex]v_y[/tex]
of the velocity when he hits the net using the law of conservation of energy.
Finally, add up the two components [tex]v = \sqrt {v_{0x}^2 + v_{_y }^2 }[/tex] and you're done.
Hope this helps :-)
Sorry, but I still don't understand. : /
How exactly do I start off? What values do I use to calculate mechanical energy then Potential?..
What about the angle given?..
Okay, how does that help me for question a. though?. How do I set up the equation after figuring out the components?.
(Please bear with me, I'm kinda slow at this.. : / )
FIY, when he is at his highest point, his velocity is zero, thus his kinetic energy equals zero and his gravitational potential energy is maximum.
You can either use the kinematic equation: [tex]v_{y}^2 - v_{0y}^2 = 2a(x - x_0 )[\tex]<br /> where vy=0 and a=-g (vertically, the acrobat undergoes free-falling motion) or use the law of conservation of energy with respect to the platform:[tex]\frac{1}{2}mv_{0y}^2 = mgh_0[\tex][/tex][/tex]
Okay, I am using the law of conversation of energy.
I first look for the total energy from the beginning of the platform using:
Em= Ep+Ek
Em=(mgh)+(mv^2 X .5 )
Em= (56.0kg)(-9.81m/s^2)(15.0m)+ (56.0kg)(21.0m/s^2)(0.5)
Em= 4107.6J
Then, I calculate the highest point but since the kinetic energy at the highest point is zero.
Em=Ep+Ek
Em-Ek= Ep
4107.6J - 0= 4107.6J
I end up getting a potential energy of 4107.6J, not the answer 9.69X10^3 J.
Nah, don't get me wrong
You should always substitute a POSITIVE value for g, say, g=+9.81 m/s^2
And as we are investigating vertically, v0y= v0*sin(theta)=21*sin20. It should work fine now :-)
I end up getting 20588.4J instead. : /
NEVERMIND. I GOT IT. : )
Thanks
No, it is not. The body is moving horizontally as well as vertically. Only the vertical component of its velocity is zero at the highest point. So only its vertical K.E. is converted into P.E.
I think you realized this, but I didn't want to let it slip by without comment.
