Klein–Gordon equation with time dependent boundary conditions.
In summary, the Klein–Gordon equation with time dependent boundary conditions has a surface in spacetime which "twists" in the radial direction.
Spinnor
430
Suppose we look for solutions to the Klein–Gordon equation with the following time dependent boundary conditions,
psi(r,theta,phi,t) = 0 zero at infinity
psi(on surface of small ball, B_1,t) = C*exp[i*omega*t]
psi(on surface of small ball, B_2,t) = C*exp[-i*omega*t]
where the small balls B_1 and B_2 have radius delta, do not overlap, and are a large distance D apart. C is a complex number and omega is some angular frequency. Assume omega > m the mass in the Klein–Gordon equation.
Will the field energy decrease as D gets smaller? Is this hard to show?
Thank you for any help!
Change things a bit. Let there be one ball below. Changes follow,
where the small ball B_1 has radius delta. C is a complex number and omega is some angular frequency. Assume omega > m the mass in the Klein–Gordon equation.
This makes an interesting "surface" in spacetime? Spacetime X phasespace?
It "twists" in the radial direction about the boundary? Phase has some r dependence (for any omega but for omega >> m things get very twisted)?
Thanks for any thoughts!
You should find the spectral decomposition of the (3D) Laplacian on the space described. For a single sphere, you should get the usual spherical harmonics times r^-n. I'm not sure what it is for two spheres.
Lets make it more interesting and add the electromagnetic field. We will still "drive" the Klein Gordon field on the surface of some small ball but now we will include the electromagnetic field. Assume the driving force starts up very quickly at t = 0 so that on the surface of a small ball the Klein Gordon field is C*exp[i*omega*t]. After a long time has gone by what rough fraction of the energy will be in the massless electromagnetic field compared with the massive Klein Gordon field and what is its general form.
5 dollars for the first answer that sounds right by me. Any takers %^)
Thanks for any help!
Assume the solution to the above problem has the form
phi(r,t) = psi(r)*E(t), and with the boundary condition,
psi(R)*E(t) = psi(R)*C*exp[i*omega*t]
We want to solve,
[Box^2 + m^2]phi(r,t) = 0, or
[Box^2 + m^2]psi(r)*E(t) = 0, or
[m^2 - omega^2]psi(r)*E(t) = E(t)[Laplacian*psi(r)], or
[m^2 - omega^2]psi(r) = Laplacian*psi(r)
Assume psi(r) = r^-1*exp(-M*r) with help from Wolfram Alpha,
http://www.wolframalpha.com/ we find out
Laplacian*psi(r) = M^2*psi(r) so
[m^2 - omega^2] = M^2
as omega > m , M = +or- i*[omega^2 - m^2]^.5
I think we throw away the negative root?
so phi(r,t) = r^-1*exp(-M*r)*C*exp[i*omega*t]
It appears this function only "twists" in the radial direction for omega > m , bad guess on my part. With this function now we might be able to come up with an answer to my last question above where we now want to "turn on" the electromagnetic field.
... Assume psi(r) = r^-1*exp(-M*r) with help from Wolfram Alpha said:
http://www.wolframalpha.com/[/url] we find out
so phi(r,t) = r^-1*exp(-M*r)*C*exp[i*omega*t]...
Depending on whether the energy in the field is increasing or decreasing we will need both signs for M?
Given
J_mu=i(phi* partial_u phi - phi partial_u phi*)
and
thenedit mistake?
J_r goes as M/r^2
J_0 goes as omega/r^2
With this and
Box^2 A_u = J_u
We should be able to find A_r and A_0 ?
... Given J_mu=i(phi* partial_u phi - phi partial_u phi*) and phi(r said:
thenedit mistake?
J_r goes as M/r^2
With this and
Box^2 A_u = J_u
So A_r and A_0 go as ln(r)?
Spinnor you are asking doubt or teaching us :-) ? by the way Nice problem to ask.
I'm glad I did not waste your time %^) thank you. I now think I can tackle the original question in this thread assuming I have not made any major errors?
Are you joking Spinnor! Its an ace level problem.Your approach seems to be correct to me but I'm not an expert.Therefore you must consult sir A.Neumaier or Sir tom.stoer.
Thank you!
1. What is the Klein-Gordon equation with time dependent boundary conditions?
The Klein-Gordon equation with time dependent boundary conditions is a partial differential equation that describes the behavior of a scalar particle in a relativistic quantum field theory. It is a generalization of the Klein-Gordon equation, which includes the effects of time-varying boundary conditions.
2. How is the Klein-Gordon equation with time dependent boundary conditions used in physics?
The Klein-Gordon equation with time dependent boundary conditions is used in many areas of physics, including quantum field theory, particle physics, and cosmology. It is particularly useful in modeling the behavior of particles in high-energy environments, such as those found in particle accelerators or the early universe.
3. What are the main features of the Klein-Gordon equation with time dependent boundary conditions?
The main features of the Klein-Gordon equation with time dependent boundary conditions include its relativistic nature, which allows for the description of particles moving at speeds close to the speed of light, and its ability to account for time-varying boundary conditions, which can significantly affect the behavior of particles in certain situations.
4. What are some applications of the Klein-Gordon equation with time dependent boundary conditions?
Some applications of the Klein-Gordon equation with time dependent boundary conditions include modeling the behavior of particles in high-energy collisions, such as those in particle accelerators, and studying the early universe during the period of inflation. It is also used in quantum field theory to describe the behavior of scalar fields.
5. What are some challenges associated with solving the Klein-Gordon equation with time dependent boundary conditions?
Solving the Klein-Gordon equation with time dependent boundary conditions can be challenging due to the complex nature of the equation and the need for advanced mathematical techniques. Additionally, accurately modeling the time-varying boundary conditions can be difficult and may require additional assumptions or approximations.
  • Quantum Physics
  • Quantum Physics
