Kleppner:Mechanisc: 7.33 Grooved cone and mass
  • Thread starter Thread starter MARX
    Cone Mass
The problem involves a cone with a groove, rotating around a vertical axis, and a block sliding down the groove under the influence of gravity. The discussion focuses on the conservation of angular momentum and the contributions of the block's velocity to the system's angular momentum.
  • Participants discuss the conservation of angular momentum and question how the block's velocity contributes to the angular momentum about the vertical axis. There are attempts to clarify the direction of the velocity components and their relevance to angular momentum.
Participants are actively engaging with the problem, raising questions about the contributions of different velocity components to angular momentum. Some have expressed understanding of the concepts, while others are still seeking clarification on specific points regarding forces and torques acting on the system.
There is an ongoing examination of the forces acting on the cone and block system, including the role of the axle in providing countertorques and maintaining stability. The discussion highlights the complexity of the problem and the subtleties involved in analyzing the motion and forces at play.
MARX
  1. A cone of height h and base radius R is free to rotate around a fixed vertical axis. It has a thin groove cut in its surface. The cone is set rotating freely with angular speed ω0, and a small block of massm is released in the top of the frictionless groove and allowed to slide under gravity. Assume that the block stays in the groove. Take the moment of inertia of the cone around the vertical axis to beI0.
    h is the height of the cone.
    (a) What is the angular speed of the cone when the block reaches the bottom?
    (b) Find the speed of the block in inertial space when it reaches the bottom.
Li = Lf
OK on this question for part a I understand that angular momentum is conserved
Li = I0*w0
the final angular momentum should it not be that of the cone plus the marble as the marble is moving downwards with a velocity v which can be calculated from mgh=1/2 m v2 and so
Lf = (I0 + mR2)*wf + m*R* √(2*g*h)*h/√(h2+R2)
the solution does not take into account the speed of the marble at the bottom IE: m*R* √(2*g*h)*h/√(h2+R2)
Last part is sinθ = h/√(h2+R2)
The problems for this chapter are really subtle and confusing me..
Can you be more specfic about the direction of that component of its velocity?
Not all components of the block's velocity contribute to its angular momentum about the vertical axis.
Why not?
that component should be contributing please see image
MARX said:
Why not?
that component should be contributing please see imageView attachment 228854
If ##\vec v## is the component in the vertical plane through the axis then ##\vec r\times\vec v## is horizontal. To contribute to the angular momentum about the vertical axis it would need to have a vertical component.
Why not? That component should be contributing. See image please.
I am sorry I don't understand r×v should be out of the page and hence contributes to L no?ℂ
Angular momentum about an axis is a vector along that axis.
A velocity out of the page would contribute to angular momentum about the vertical axis, but the component of the velocity vector that you are considering is through the vertical axis, so cannot contribute to angular momentum about it.
Thanks. Yes I completely understand but the velocity is not vertically down it is at an angle as in image and the cross product spans an inverted cone with a horizontal top circle as the cone in question is spinning ie it has a component of angular momentum along that vertical axis that adds up as cone rotates. What am I missing?
Indeed, but that component is not given by the v you calculated from mgh.
Think about the cone+block system. What forces act on it? Which if any have a torque about the axis?
OK thank you very much. I got it. I wrote the vectors of r and v in cylindrical coordinates and indeed the cross product generates zero momentum along the vertical axis. You are right no external toques anyways act on the system so angular momentum has to be conserved vertically but not necessarily in any direction. Am I right.
Nearly.
Two external forces on the system are gravity and a vertical force opposing gravity. But those combine to produce a torque tending to topple the cone. So there is also a torque from the axle to keep it upright. But none of those have a torque component about the vertical axis.
haruspex said:
Nearly.
Gravitation of cone and cube got it
what is the Force opposing gravity?
what is the source of torque from axle?
The cone must be mounted on an axle to keep it in place. The forces from that will be whatever is required to keep the centre line where it is, in altitude, position and orientation.
Since the block and cone (maybe) have weight, this must include a vertical force to stop the cone moving down. It will be more than the weight of the cone but less than the combined weight, since the block is accelerating.
This upward force will be in the same line as the weight of the cone, but the block is pressing down on one side, resulting in a torque. So the axle must provide a countertorque. This will be horizontal and normal to the plane containing the axle and the block.
Also, the block is pushing sideways on the cone, so the axle must provide an opposing horizontal force.
Since the cone is free to turn on the axle, the axle cannot provide any force or torque that has a moment about itself.
Ok got it thanks very much for this thorough and succinct explanation.
  • · Replies 16 ·
