Kreiszig 1.3-9: l-infinity is not seperable
  • Context: Graduate
  • Thread starter Thread starter Rasalhague
The discussion centers on the proof that the metric space l-infinity is not separable, as demonstrated in Kreiszig's "Introductory Functional Analysis with Applications," specifically example 1.3-9. The proof utilizes a bijection between the interval [0,1] and the set Y of sequences consisting solely of 0's and 1's, establishing that Y is uncountable. It concludes that any dense subset M of l-infinity must also be uncountable, as each of the uncountably many balls of radius 1/3 centered on elements of Y must contain elements of M. The participants clarify misconceptions regarding limit points and the nature of the bijection involved.
  • Understanding of metric spaces and separability
  • Familiarity with the concepts of bijections and surjections
  • Knowledge of sequences and their properties in functional analysis
  • Basic comprehension of cardinality and uncountability
  • Study the properties of l-infinity in functional analysis
  • Learn about the concept of separability in metric spaces
  • Explore the implications of bijections in set theory
  • Investigate the role of dense subsets in topology
Mathematicians, students of functional analysis, and anyone interested in the properties of metric spaces and their implications in topology and set theory.
Rasalhague
Kreiszig: Introductory Functional Analysis with Applications, example 1.3-9, states that the metric space l^{\infty} is not seperable. He invites the us to consider the bijection between the interval [0,1] and the set Y of sequences, y = (\eta_1, \eta_2, ...), whose terms consist of no number other than a 1 or a 0:
\hat{y}\in \left [ 0,1 \right ] = \sum_{k=1}^{\infty} \frac{\eta_k}{2^k}.
The existence of this bijection, and the fact that [0,1] is uncountable, shows that Y is uncountable.
Consider the uncountably many balls of radius 1/3, each centered on one y in Y. (Whether open or closed is unstated, so I guess that's not relevant.) These balls don't intersect.
If M is any dense set in in l^{\infty}, each of these nonintersecting balls must contain an element of M.
Therefore M is uncountable. M was chosen arbitrarily. Therefore, he concludes, l^{\infty} has no dense subset which is countable. In other words, l^{\infty} is not seperable.
My question. Am I right in thinking this assumes that no ball can contain a limit point of M which is not in M? If so, why is that?
I'm a bit confused on why you would think of limit points here. You suppose M is dense, right? Well, in that case, every point of of \ell^\infty (which is not in M) is a limit point of M! So that's not what's going on here.
Can you tell us where you're stuck in the proof??
Also note that the function you mention (i.e. the one that sends \hat{y} to \sum{\eta_k/2^k} ) is NOT a bijection. It is merely a surjection! It is indeed true that a point in [0,1] can have two binary representations:
\frac{1}{2}=\frac{1}{2}+0+0+0+0+\hdots=\frac{1}{4}+\frac{1}{8}+\frac{1}{16}+...
Re. #3. Ah, yes, thanks for pointing that out. I thought, for some reason, he was saying that Y is uncountable because it has the same cardinality as [0,1], but I see now he actually only needs to show that it has at least as great a cardinality as [0,1]. (Incidentally, do you know if there exists a bijection between them?)
Re. #2. Got it now! (I hope.)
There are uncountably many balls, and each contains an element of l-infinity, namely each y in Y. In each ball, either its y is in M, or its y is a limit point of M. So if its y is not in M, then this y is a limit point of M, so every open ball around an element of Y, including the ball indicated, must contain an element of M. Therefore every ball of radius, say, 1/3 around some element of Y must contain an element of M. Therefore M too has at least as great a cardinality as [0,1], and so is uncountable.
I think what was confusing me was only that I'm new to some of the concepts and they hadn't bedded down yet in my brain. I just didn't follow through the reasoning far enough.
Yes, that is both correct. :biggrin:
And it is indeed true that there is a bijection between [0,1] and the subset of \ell^\infty that you mention. However, finding that explicit bijection is not easy...
Personally, I despise decimal expansions, and I try to avoid them whenever I can.
In this case, just take Y=\{0,1\}^\mathbb{N}, the set of sequences consisting of 0's and 1's. This is an uncountable subset of \ell\infty, with any pair distinct elements a distance of 1 from each other. The uncountability is even easier now: there is an obvious bijection between Y and the power set of \mathbb{N}.
Now suppose Z is a dense subset. By definition this means that any ball around any element meets Z. In particular, for every y in Y the ball B(y) at y of radius 1/2 contains an element z(y) of Z. But if y' in Y is another element, then B(y') and B(y) are disjoint (as ||y-y'||=1), so z(y)/=z(y'). Hence the map Y->Z, y\mapsto z(y) is an injection . As Y is uncountable, Z must be too.
(I find this argument also a bit clearer than talking about 'uncountably many balls')
Thanks for the confirmation micromass, and thanks Landau for the extra insight. That's very helpful.
  • · Replies 48 ·
12K
  • · Replies 67 ·
11K
  • · Replies 19 ·
