How Does Air Resistance Affect the Acceleration of Falling Objects?
This discussion focuses on the impact of air resistance on the acceleration of falling objects, specifically comparing coffee filters and rocks. The participants utilized Newton's second law (F = ma) to analyze how air resistance affects lighter objects more significantly than heavier ones. They conducted an experiment using a motion sensor to record the position and velocity of falling coffee filters, concluding that increased mass allows objects to better overcome air resistance, thus approaching gravitational acceleration (g). The discussion emphasizes the importance of accurately modeling falling objects and understanding the relationship between mass, air resistance, and acceleration.
  • Understanding of Newton's laws of motion, particularly F = ma
  • Familiarity with kinematic equations, specifically s = 1/2gt²
  • Basic knowledge of graph interpretation, including x/t and v/t graphs
  • Experience with motion sensors and data collection in physics experiments
  • Explore the effects of surface area on falling objects using different materials
  • Learn about terminal velocity and its relationship with mass and air resistance
  • Investigate the mathematical modeling of motion using calculus, particularly derivatives
  • Study the principles of drag force and its impact on various shapes and sizes of objects
Students in physics courses, educators teaching motion concepts, and anyone interested in the dynamics of falling objects and the effects of air resistance.
nso09
I apologize if my thought process is unrefined. I didn't really learn and remember much from high school physics that benefits me right now in college physics.
Until this point we covered Newton's three laws of motion. And instead of a cotton ball, we used a coffee filter.
"Our reasoning is this: Each air molecule, on impact, imparts a small force to a falling object. Using the traditional force formula F = ma (Newton, 1687), we see that each collision effectively reduces the gravitational acceleration of any object falling through air by an amount that is inversely proportional to that object’s mass (i.e., a = F ⁄ m ). Thus the light cotton ball is slowed more than a comparably sized (and heavier) rock."
Since coffee filters fall slower than the rock since it is lighter, then we should modify the formula for distance s fallen in time 5. Instead of s=1/2gt^2,
the correct model for falling cotton should be s=1/2kt^2 where k is an acceleration smaller than g.
Confirm or deny this.
(we suggest that the effect of air resistance is greater on the coffee filter because it is lighter)
You have a coffe filter, meter stick, stopwatch, motion sensor, and a x/t and v/t graph.
F=ma, ay=1/2at^2
We did this lab today but my partners and I were stumped and likely performed an incomplete or probably unrelated experiment.
We initially thought we should experiment on the effect of surface area on how fast the filter will fall on the ground. But after talking with my other two partners, we just decided to experiment on the effect of increased mass on the rate of falling.
What we did was we used the motion sensor to record the position and velocity over time of initially one coffee filter on a fixed height. Then we added a coffee filter on the first filter to increase the mass. We did this one more time so the last trial was recording the x/t and v/t of 3 coffee filters layered on one another.
What we found was the v/t got more leveled and less steep. From this, we figured that as we increased the mass of an object, it was more able to overcome the force of air resistance as it falls on the ground so "k" approached closer to "g" instead of "k" being an acceleration smaller than "g."
I feel as if that our experiment didn't properly address the fact that regardless of mass, whether the coffee filter is lighter, it should still fall at the same time as a rock.
What did we miss and how could we have done this experiment better to address the fact that even though the coffee filter was lighter, s=1/2gt^2 should still apply and that g SHOULD NOT be changed to "k" which is a smaller acceleration than g?
The problem is not looking at the result and finding different k. The problem is showing that s=kt^2/2 is not a good description. I suggest you look at your x/t graph, is it a parabola? The same for your v/t graph, is it a linearly increasing function?
The x/t graph was a straight line with negative slope(since the filter was released from a higher point) and the v/t graph was also about a straight line with a negative slope from what I can remember when we used the pasco motion detector
Just think inspecting the graph of v vs t, can you conclude that the motion is with zero acceleration, constant non-zero acceleration, or varying acceleration. Then think of modelling. There is no question of remebering just inspect the graph and think about it.
each varying graph had a certain acceleration but the acceleration in each particular graph was non-zero
Good but is it constant or varying can you distinguish between average acceleration and instantaneous acceleration from v-t graph
If you cannot easily upload the results, it might help us commentators if you could give a bit more detail about them. I assume the motion sensor gives 'instantaneous' velocities. Can you post the times, speeds and positions of just the first three measurements for the single paper? If that does not include a time zero, are you adding a time zero datapoint to your graph?
would average acceleration be the final velocity-initial velocity divided by tfinal-tinitial? I'm not sure how to know instantaneous acceleration form a v-t graph though by just looking at it
We turned in our graphs to our TA and didn't save our data since we were so behind with our lab that we rushed. :( I'm so sorry
How would you estimate velocity at some instant from a distance-time graph?
Draw any graph other than straight line and just think about it it is a mathematical skill!
i know that if you have a curvy graph like y=x^2, you take the derivative of that to find the slope at that particular x.
So instantaneous acceleration would be just the slope of the velocity graph if it is approximately linear?
i would look at the x/t graph and estimate the slope of that which I noticed was negative
Yes, the slope (even if it is not approximately linear, though that does make it harder to judge).
Likes nso09
  • · Replies 39 ·
  • · Replies 27 ·
  • · Replies 35 ·
