Lagendre Polynomials - using the recursion relation
The discussion revolves around the properties and calculations involving Legendre polynomials and Hermite polynomials, specifically using recursion relations to find coefficients and polynomial forms. The original poster presents two problems related to these polynomials and expresses confusion regarding the relationships between coefficients and their derivations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the use of recursion relations to derive polynomial coefficients and question the logical patterns behind the coefficients of the polynomials. There are discussions about the nature of even and odd coefficients and their implications for polynomial solutions.
Some participants have provided clarifications regarding the relationships between coefficients and the conditions under which the series terminates. Others have expressed their intent to work through the problems with the new understanding, while some still seek further examples or guidance to solidify their comprehension.
There is mention of potential confusion regarding the dependence of coefficients on the parameter p and the implications of the recursion relations. Participants note that the original problem may lack sufficient information for clarity.
rwooduk
(1) P_{l}(u) is normalised such that P_{l}(1) = 1. Find P_{0}(u) and P_{2}(u)
We have the recursion relation:
a_{n+2} = \frac{n(n+1) - l(l+1)}{(n+2)(n+1)}a_{n}
I'm going to include a second similar question, which I'm hoping is solved in a similar way, so I can relate it to the above question:
(2) Show that the functions H_{0}(x) = 1, H_{1}(x) = 2x, H_{2}(x) = 4x^{2} - 2, H_{3}(x) = 8x^{3} - 12x have coeffiecients that obey the recursion relation
a_{n+2} = \frac{2(p-n)}{(n+2)(n+1)}a_{n}
I have the answer for (2) and it makes no sense to me, i tried to tabulate why:
For P = 0, 1, 2 we have Even a_{0} values of 1, 0, -2 respectively
For P = 0, 1, 2 we have Odd a_{1} values of 0, 2, 0 respectively
And for P = 0, 1, 2 we have n values of 0, 1, 0 respectively
Where do these come from? I've looked for how to solve the above problems, and can't find a step by step example anywhere, it follows no logical pattern.
Any help would be VERY much appreciated.
Thanks.
##a_0## and ##a_1## are arbitrary constants. The rest of the coefficients can be expressed in terms of them through the recurrence relation. In both of these problems, you're looking for polynomial solutions to the differential equation. That means that the series needs to terminate for some value of ##n##. Looking at the recurrence relation, you can see this will happen when ##p=n##.
Let's consider the case when ##p=2##. The even coefficients will be given by
\begin{eqnarray*}
a_2 &= -\frac{2(2-0)}{(0+2)(0+1)}a_0 = -2a_0 \\
a_4 &= -\frac{2(2-2)}{(2+2)(2+1)}a_2 = 0 \\
a_6 &= -\frac{2(2-4)}{(4+2)(4+1)}a_4 = 0
\end{eqnarray*} (Your recurrence relation has a sign error.) The remaining even coefficients will vanish as well. The odd coefficients will be proportional to ##a_1##, but the series will never terminate because you'll never have ##p=n## because ##p=2## is even while ##n## will always be odd. To avoid an infinite series solution, we set ##a_1=0##.
At this point, we have one polynomial solution, namely ##H_2(x) = a_0 + a_2 x^2 = a_0(1-2x^2)##. What value to choose for ##a_0##? It depends on how you want them normalized.
That's a very clear explanation, many thanks!
I'll try work through the questions with this knowledge and see how i do.
Thanks again!
hm why does ##a_{6} = 0## ?
and where does the ##x^{2}## come from?
thanks
Because ##a_4=0##.
vela said:
Because ##a_4=0##.
yep just realized thanks and the ##x^{2}##?
also for p = 1, do i just use odd values of n? n=1 would not be possible, but then for n=3 i get ##a_{5} = \frac{2(1-3)}{(3+2)(3+1)} = \frac{-4}{20}## not sure what to do with that
if possible please could someone do a couple more, i still can't see a logical process :-/
or if someone could direct me to a similar problem somewhere?
Thanks.
First of all, spend some time really trying to understand what the problem is asking for; then you can worry about how to solve the problem. As I read it, you have polynomials ##H_p(x)## for ##p = 0,1,2,3,\ldots##, and it looks like:
(1) For even ##p##, ##H_p(x)## contains only the even powers ##x^0 (=1), x^2, \ldots, x^{p-2}, x^p##.
(2) For odd ##p##, ##H_p(x)## contains only the odd powers ##x, x^3, \ldots, x^{p-2}, x^p##
In a court of law you could argue that the question did not contain enough information to allow you to say this with certainty, but more-or-less standard usage and common sense implies it with little room for doubt.
So, you are given a few examples of ##H_p(x)## for small ##p## and are asked to verify that the coefficients obey a certain, given, recursion. What is preventing you from just checking if those coefficients really do obey the recursion?
Oh...I see that there might be one source of confusion: the question did not say it, but the coefficients ##a_i## also depend on ##p##; that is, ##a_0## is different for different values of ##p##, as is also the case for ##a_1##, etc. So, perhaps the question should really have given the recursion as
a_{n+2}(p) = \frac{2(p-n)}{(n+2)(n+1)}a_{n}(p)
Harder questions would be: how on Earth did the recursion arise? Who thought of it, and why? But those are outside the actual scope of the question, assuming you quoted the question accurately.
Many thanks for the reply! I'm going to give it one last go with all the information presented in this thread (and my lecture notes, which cover more the orthogonality property so aren't that useful) and see where I get with it. Least I now understand where the x comes from in the solution!
Thanks again for all the help!
update: finally figured this out!
i also found a very useful video for those interested:
start at 12:50 to relate to op
