Lagrange Multiplier question with solid attempt
5 replies · 2K views
tamintl
Use the method of Lagrange multipliers to find the maximum and minimum values of the function
f(x, y) = x + y2
subject to the constraint g(x,y) = 2x2 + y2 - 1
none
We need to find [itex]\nabla[/itex]f = λ[itex]\nabla[/itex]g
Hence,
[itex]\nabla[/itex]fx - λ[itex]\nabla[/itex]gx = 0
Which becomes, 1 - λ(4x) = 0
[itex]\nabla[/itex]fy - λ[itex]\nabla[/itex]gy = 0
Which becomes, 2y - λ = 0
Now we have: x = 1/4λ and y = λ/2
I assume I am right in now subbing x and y into the constraint...
To give us: 2/16λ2 + λ2/4 - 1 = 0
It seems a bit messy considering this is an elementary part of my homework? Have I gone wrong somewhere?
Regards as always
Ray Vickson said:
Your [itex]\partial{L}/\partial{y}[/itex] is incorrect; try again.
RGV
Wow, rookie error..
yep dL/dy = 2y - λ(2y)
so λ = 1
Thus, x=1/4
Put this into constraint to get: y=7/8
So (1/4,7/8) is a point..
How do i find the maximum and minimum? thanks
Since specific values of [itex]\lambda[/itex] are not part of the "solution" of problems like these, I find it is often a good step to start by dividing one equation by another, eliminating [itex]\lambda[/itex] at the start. Here, your equations are [itex]1= 4\lambda x[/itex] and [itex]2y= 2\lambda y[/i2tex]. Dividing the second equation by the first:<br /> [tex]\frac{2y}{1}= \frac{2\lambda y}{\lambda x}= \frac{2y}{x}[/tex]<br /> which reduces to x= 1 or y= 0.<br /> <br /> However, you say your constraint is "[itex]g(x,y)= 2x^2+ y^2- 1[/itex]" which is not a constraint at all. Did you mean [itex]g(x,y)= 2x^2+ y^2= 1[/itex]? If so, set x= 1 in that and solve for y, then set y= 0 and solve for x.[/itex]
The statement that "specific values of lambda are not part of the solution ..." is either misleading or wrong, depending on exactly how you meant it. ONE of the max or min points IS obtained by looking at lambda = 1 and seeing the consequences.
RGV
