Lagrange Multipliers. All variables cancel
The problem involves finding the maximum and minimum temperatures within a cannonball modeled as a sphere, given a specific temperature distribution function T(x,y,z) = 60(y² + z² - x²). The discussion centers around the application of Lagrange multipliers to identify critical points under the constraint of the sphere's geometry.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the implications of setting the gradients equal under the Lagrange multiplier method, questioning the cancellation of variables and the resulting values of λ. There is discussion about the significance of critical points, particularly when variables equal zero, and how these relate to the constraint of the sphere.
The discussion is ongoing, with participants examining different cases for the variables and their implications for finding extrema. Some guidance has been offered regarding the interpretation of λ values and the constraints, but no consensus has been reached on the final approach or conclusions.
Participants note the importance of the constraint y² + z² + x² = 1 and how it affects the identification of maximum and minimum temperatures. There is also mention of the potential for multiple extrema and the need to consider both interior and boundary points in the analysis.
NoOne0507
A cannonball is heated with with temperature distribution T(x,y,z)=60(y2+z2-x2).
The cannonball is a sphere of 1 ft with it's center at the origin
a) Where are the max and min temperatures in the cannonball, and where do they occur?
\nablaf=λ\nablag
Where g is the the constraint and λ is the common ratio.
\nabla= fx i + fy j + fz k
The cannonball is the restraint so
λ\nablaf = 2xλ i + 2yλ j + 2zλ k
\nablaT = -120x i + 120y j + 120z k
2xλ = -120x, λ= -60
2yλ = 120y, λ = 60
2zλ = 120z, λ = 60
I don't know where to go from here. All the variables canceled so I can't relate them to each other, and the λs are different.
2*x*lambda=(-120*x) doesn't mean lambda=(-60). It means either x=0 OR lambda=(-60). You have to consider both cases.
But couldn't x be any value? For x ≠ 0, λ=-60. And then when x = 0 we get 0=0 with no λ.
If you do that for all the values you can get x=y=z=0, plug into the constraint and get the center of the circle, with no value for λ. How would that help find the max and the min?
x=y=z=0 is an important point. You should keep it in mind. It's an interior critical point. But yes, if x is nonzero then lambda=(-60). What does that tell you about y and z? If x is zero then lambda could be 60. Still doesn't tell you anything about y and z. But now you have to use the constraint y^2+z^2-x^2=1. You have to think this all through. You don't necessarily get a finite number of extrema on the boundary. There might be a lot of them.
Well if x=0 then the constraint becomes y^2+z^2=1, with λ=60. So would the maxima occur anywhere in the yz unit circle? Which would yield (0, y, ±√(1-y^2)) as the maxima?
And then the smallest λ would occur at x≠0, and y=z=0? Which would give Minima on
x: [-1,0) U (0,1]
y=0
z=0
Or am I off-base here?
x: [-1,0) U (0,1]
y=0
z=0
Getting closer. So the points to think about are (1,0,0), (-1,0,0), (0,y,z) along the circle where y^2+z^2=1 and the interior critical point at (0,0,0). What is the value of T in each of those cases?
T(x,y,z)=60(y^2 + z^2 - x^2)
T(0,0,0) = 0
T(1,0,0) = -60
T(-1,0,0) = -60
T(0,y,z) = 60(y^2+z^2), but since this is along a circle T(0,y,z) = 60
Which gives the minimum at (1,0,0) and (-1,0,0), and the max at (0,y,z) where y^2+z^2=1.
Okay, so from (almost) the beginning:
λ = -60, x≠0, y=z=0
λ = 60, x=0
Since the minima will occur at the smallest λ, and x≠0 provides that λ, but it also requires y=z=0 for that to occur. This leaves T(x,0,0) = -60x2 on -1≤x≤1 because of the unit sphere restriction. x=0 is a critical point, and the end points need to be checked, so T(-1,0,0) = T(1,0,0) = -60, and T(0,0,0)=0 The absolute min occurs at (-1,0,0) and (1,0,0). While (0,0,0) is a relative max (or the absolute max on the interval).
The maxima occur at x=0 since λ =60 when x=0. This leaves T(0,y,z)=60(y2+z2), with the restriction y2+z2≤1. The maxima are clearly the endpoints, y2+z2=1. So the maximum value for T occurs along that circle, which gives T(0,y,z)=60, where y2+z2=1.
Hey, it makes sense. Thank you.
T(0,0,0) = 0
T(1,0,0) = -60
T(-1,0,0) = -60
λ = -60, x≠0, y=z=0
λ = 60, x=0
Of course, this problem is easy to solve without calculus. T = 60(y^2+z^2-x^2) <= 60(y^2+z^2+x^2) <= 60 in the sphere x^2+y^2+z^2<=1. Furthermore, we reach T=60 at any point on y^2+z^2=1, x=0. Also: T >= 60*(-x^2) >= -60, and we reach T=-60 at y=z=0, x=+-1. It is nice to see that the Lagrangian multiplier method dies, indeed, give such results.
RGV
Personally, I wouldn't use "Lagrange Multipliers" for this at all. The temperature function is T(x,y,z)= 60(y^2+ z^2- x^2)= 60(x^2+ y^2+ z^2- 2x^2) which in spherical coordinates is T(\rho, \theta, \phi)= 60(\rho^2- 2\rho^2sin^2\phi cos^2(\theta)). On the surface of the sphere, \rho= 1 so that is T(\theta, \phi)= 60(1- 2sin^2(\phi)cos^2(\theta).
