Lagrangian question - rough ball on moving wedge
The discussion revolves around a Lagrangian mechanics problem involving a solid ball on a moving wedge. The user attempts to derive the total kinetic energy of the system, accounting for both the translational and rotational motion of the ball. The kinetic energy expressions are presented, including terms for the wedge and the ball, with specific focus on the dot product evaluation that introduces the term 2\dot{X}\dot{x}\cos{\phi}. The community provides insights on vector operations and emphasizes the need to express the kinetic energy in terms of a single variable.
  • Understanding of Lagrangian mechanics
  • Familiarity with vector calculus and dot products
  • Knowledge of rotational dynamics, specifically moment of inertia
  • Basic principles of kinetic energy in multi-body systems
  • Study the derivation of kinetic energy in Lagrangian mechanics
  • Learn about the relationship between translational and rotational motion
  • Explore vector calculus, focusing on dot products and their applications
  • Review examples of Lagrangian problems involving multiple moving bodies
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for insights into Lagrangian problem-solving techniques.
venerium
(context: I'm studying for a test, and this is a question from a past exam paper.)
"A wedge of mass M with angle \phi is free to slide on a frictionless horizontal table. A solid ball of radius a and mass m is placed on the slope of the wedge. The contact between the ball and the wedge is perfectly rough.
(a) Derive an expression for the total kinetic energy of this system."
I've chosen X to represent the horizontal displacement of the wedge, and x as the displacement of the ball along the surface of the wedge.
T for the wedge is easy enough \frac{1}{2}M\dot{X}^2.
Total T for the ball must be: T due to rotational motion of the ball + T due to linear velocity (down the wedge + due to the wedge's own velocity).
We're given I = \frac{2}{5}ma^2 for the ball, so I get:
T_{rot} = \frac{1}{2}I\omega^2 = \frac{1}{2}\frac{2}{5}ma^2\omega^2 = \frac{1}{5}ma^2\frac{\dot{x}^2}{a^2} = \frac{m\dot{x}^2}{5}
(Am I correct in only using the \dot{x} velocity component for \omega = \frac{v}{r}?)Using my coordinates, the total velocity of the ball is:
\vec{v} = \dot{X}\widehat{I} + \dot{x}\widehat{i} (i being the unit vector in the direction of x)
From worked solutions to similar problems with blocks I've found online, I think the linear T for the ball must be:
T = \frac{1}{2}m\vec{v}\cdot\vec{v} = \frac{1}{2}m\dot{X}^2 + \frac{1}{2}m\dot{x}^2 + m\dot{X}\dot{x}\cos{\phi}
But I'm not sure where that third 2\dot{X}\dot{x}\cos{\phi} term is coming from in the evaluation of the dot product. I understand that it couldn't just be \dot{x}^2 + \dot{X}^2, but how do you go about evaluating the dot product in this case?
Any hints would be really appreciated, I'm still trying to develop an intuition for these Lagrangian problems. Cheers!
Welcome to PF, venerium!
For any two vectors A and B,
(A + B)##\cdot##(A + B) = A##\:\cdot##A + 2A##\:\cdot##B + B##\:\cdot##B.
You can show this using the more basic identity:
A##\:\cdot##(B + C) = A##\:\cdot##B + A##\:\cdot##C
Ah, thank you! Thought it would be something simple - I'm a bit rusty on my math. Does the rest of my solution/thinking look fine?
And thanks for the welcome, I've been a lurker for years now so it's about time I joined. :P
It all looks good to me.
Glad you did!
However, ##X## and ##x## are not independent variables. So, you would need to go on and write T in terms of just one of the variables ##\dot{X}## or ##\dot{x}## before using it in the Lagrangian.
