Laplace equation in polar coordinates.
The Laplace equation in polar coordinates is expressed as \(\nabla^2 u = \frac{1}{r} \frac{\partial}{\partial r} \left( r \frac{\partial u}{\partial r} \right) + \frac{1}{r^2} \frac{\partial^2 u}{\partial \theta^2}\). It is crucial to confirm that the function \(u\) is represented as \(u(r, \theta)\) rather than \(u(x, y)\) when working in polar coordinates. The derivation of the Laplace operator in polar coordinates can be validated through the action principle, leading to the Euler-Lagrange equations. For accurate applications, one must utilize the appropriate coordinate system based on the function's representation.
  • Understanding of the Laplace equation
  • Familiarity with polar coordinates
  • Knowledge of the Euler-Lagrange equations
  • Basic concepts of differential forms
  • Study the derivation of the Laplace operator in polar coordinates
  • Learn about the action principle in physics
  • Explore differential forms and their applications in vector calculus
  • Investigate the Euler-Lagrange equations in the context of variational calculus
Mathematicians, physicists, and engineers who are working with partial differential equations, particularly those dealing with Laplace's equation in various coordinate systems.
yungman
\nabla^2 u=\frac {\partial ^2 u}{\partial x^2}+\frac {\partial ^2 u}{\partial y^2}=\frac {\partial ^2 u}{\partial r^2}+\frac{1}{r}\frac {\partial u}{\partial r}+\frac{1}{r^2}\frac {\partial ^2 u}{\partial \theta^2}
I want to verify ##u=u(r,\theta)##, not ##u(x,y)##
Because for ##u(x,y)##, it will just be ##\frac {\partial ^2 u}{\partial x^2}+\frac {\partial ^2 u}{\partial y^2}##
Thanks
I know the derivation, I just want to confirm as none of the books or notes specify this.
It should be ##u(r,\theta)## not ##u(x,y)##.
Of course for \vec{r} \neq 0 you have
u(\vec{r})=u[\vec{r}(r,\theta)]=u[\vec{r}(x,y)].
The vector operators are better defined through covariant integrals than by brute force as in UltrafastPED's source, although it's of course a valid way to find the expression for the covariant differential operators.
A third, more physicist's way, is to use the action principle. Define the action
A<u>=\int_{\mathbb{R}^2} \mathrm{d}^2 \vec{r} \left [\frac{1}{2}(\vec{\nabla} u)^2+u \Phi \right],</u>
where \Phi is an arbitrary external field. Taking the variation you see that the stationary point is
\frac{\delta A}{\delta u}=0 \; \Rightarrow \; \Delta u=\Phi.
To evaluate thus the Laplace operator in polar coordinates, you simply write out the action in these coordinates. You only need the gradient in polar coordinates, which is very easy to derive by using differential forms:
\mathrm{d} u=\mathrm{d} \vec{x} \cdot \vec{\nabla} u=\mathrm{d} r \vec{e}_r \cdot \vec{\nabla} u + r \mathrm{d} \theta \vec{e}_\vartheta \cdot \vec{\nabla} u=\mathrm{d} r \partial_r u + \mathrm{d} \theta \partial_{\theta} u.
Comparison of both sides of the last equation of this line shows that
\vec{\nabla} u = \vec{e}_r \partial_r u + \vec{e}_{\theta} \frac{1}{r} \partial_{\theta} u.
Further you have
\mathrm{d}^2 \vec{r}=r \mathrm{d} r \mathrm{d} \theta,
and thus
A<u>=\int_0^{\infty} \mathrm{d} r \int_0^{2 \pi} \mathrm{d} \theta r \left [\frac{1}{2}(\partial_r u)^2+\frac{1}{2r^2} (\partial_{\theta}) u + u \Phi \right].</u>
Then via the Euler-Lagrange equations you get the stationary point of the action as given by
\frac{\partial}{\partial r} \left (r \frac{\partial u}{\partial r} \right )+\frac{1}{r} \frac{\partial^2 u}{\partial \theta^2}=r \Phi,
and finally dividing by r
\Phi=\Delta u=\frac{1}{r} \frac{\partial}{\partial r} \left (r \frac{\partial u}{\partial r} \right )+\frac{1}{r^2} \frac{\partial^2 u}{\partial \theta^2}.
See steps (4) and (5).
If your function is expressed as u(x,y) you should use the cartesian form.
If it is in polar form then you should use the polar form.
Otherwise you have to go through all of the steps (4) and (5), making use of the chain rule.
  • · Replies 17 ·
  • · Replies 16 ·
