Laplace Transform unit step function
9 replies · 3K views · last reply
JavierOlivares
g(t) = (t+1)us(t) - (t-1)us(t-1) - 2us(t-1) - (t - 2)us(t-2) + (t-3)us)(t - 3) + us(t-3)
unit step function us(t-3) is same as u3 (t)
Shift in time:
L[f(t - T)us(t-T)] = e-TsF(s)
us(t) ↔ 1/s
t ⇔ 1/s2
1/s2 + 1/s - e-s/s2 + e-s/s - 2e-s/s - e-2s/s2 + 2e-2s/s + e-3s/s2 - 3e-3s/s + e-3s/s1/s(1 - e-s +2e-2s - 2e-3s) + 1/ s2(1 - e-s - e-2s + e-3s)My professor gave us a different answer online. It seems correct online. Any advice would be great thank you.
  • Typeset piecewise expression g(t) written as a sum of terms (t+1)u_s(t), -(t-1)u_s(t-1), -2u_s(t-1), -(t-2)u_s(t-2), +(t-3)u_s(t-3) and +u_s(t-3), using unit step functions u_s.
Shift in time:
us(t) ↔ 1/s
t ⇔ 1/s2
I get an answer different from yours, but I don't know if it is the same as your professor's answer, since you do not tell us what that is.
I just did what I usually do for such problems, which is to avoid using all the shifting rules, etc., and just do the integral ##\int_0^{\infty} e^{-st} f(t) \, dt## directly. First, though, we need to figure out ##f(t)## in a more usable (piecewise) form. For example, between ##t = 0## and ##t = 1## only the first term is nonzero, so ##f(t) = t+1## in that interval. Between ##t = 1## and ##t = 2## the second and third terms also appear, resulting in ##f(t) = t+1 -(t-1) - 2 = 0## in ##(1,2)##. Keep going like that until you have a complete description of ##f(t)## on ##(0,\infty)##, then integrate. Of course, since you will have a piecewise description of ##f(t)## you will need to split up the integral into several pieces. And, of course, you need to know integrals such as ##\int_a^b e^{-st} \, dt## and ##\int_a^b t e^{-st} \, dt##.
Attached
  • Graph of g(t) against t: a rising line from 1 at t=0 to 2 at t=1, a drop to 0, zero until t=2, then a falling line to -1 at t=3, then zero. Below it are the Laplace transform expressions G(s) for g(t).
  • Homework problem 2-4: plot of piecewise linear g(t) against t, rising from 1 at t=0 to 2 at t=1, dropping to 0 and staying there until t=2, then sloping down to -1 at t=3, and 0 after; with G(s) written below as Laplace transform formulas.
  • Graph of g(t) against t: a rising line from 1 at t=0 to 2 at t=1, a drop to 0 at t=1, zero until t=2, then a line falling to -1 at t=3, then zero. Below it, the Laplace transform G(s) written as a sum of exponential terms over s and s squared.
  • Graph of g(t) against t: a rising line from 1 at t=0 to 2 at t=1, a drop to 0 at t=1, zero until t=2, then a line falling to -1 at t=3, then zero, with the formula for g(t) and its Laplace transform G(s) above and below.
Our professor wanted us to do it with shifting rules and easy transforms for exams since integrating would take too long for more tedious problems. Sorry I should've mentioned that earlier. Thanks for the reply.
Your solution is OK now.
Shifting, etc., works well too, but you need to be careful: your first solution contained some fatal errors. For example, you apparently said that
[tex]- (t - 2)\, u(t-2) \rightarrow - e^{-2s}/s^2 + 2e^{-2s}/s \; \Longleftarrow \:\text{false!}[/tex]
The shifting rule gives
[tex]- (t - 2) \, u(t-2) \rightarrow - e^{-2s}/s^2[/tex]
You would only get the extra ##2e^{-2s}/s## term if you had started with ##-(t-4)\,u(t-2)##.
Okay thanks for clearing that up. I think that's where I keep messing up. The last post was my professors answer and yeah I got the right answer this time by following what you said.
So I also get for : -2*us(t - 1) ↔ -2*e-2s/s
I think that's what you mean right? The shifting property for f(t - T) ↔ F(s) means that I'm only taking the Laplace of t? That's what you did in your response.
I don't understand your question. I stated exactly what I meant, so I don't know how I can re-word it.
I guess I would have thought -(t - 1)*us(t - 1) would be the same as -t* us(t - 1) + 1*us(t - 1). I factored out -(t - 1). My question is why can't I just do that?
I'll make up a different example to make sure I understand it. Let's say I had:
(3t - 1)*us(t - 1) So I got to have (3t - 1) be the same as (t - 1) for this property to work? If yes then:
3*(t - 1/3)*us(t - 1) = 3 * (t - 1 + 2/3)*us(t - 1)
***I made the function this (t - 1 + 2/3) so it equals (t-1).***
So f(t) = t + 2/3 would be the same as:
3*[(t - 1)*us(t - 1) + 2/3*us(t - 1)]
Taking Laplace I get:
3*e-s/s2 + e-s/s.
Hopefully I made this clear. So I asked two questions why can't I do what I did before and given my example is my logic correct?
3*e-s/s2 + e-s/s.
3*e-s/s2 + e-s/s.
3*e-s/s2 + e-s/s.
If ##f(t) = t \, u(t)## then ##f(t-a) = (t-a) \, u(t-a)##, so shifting applies directly to give the LT as ##e^{-as}/s^2##, with almost no work. If you write ##(t-a)\,u(t-a)## as ##t \, u(t-a) - a \, u(t-a)##, you have destroyed the shifting representation. You could write ##t \, u(t-a)## as ##f_1(t-a)##, where ##f_1(t) = (t+a) \, u(t)##, but what would be the point of that?
In your second example,
[tex](3t-1) \, u(t-1) = [3(t-1) + 2] \, u(t-1) = f_1(t-1) + f_0(t-1),[/tex]
where ##f_0(t) = 2 u(t)## and ##f_1(t) = 3 t\, u(t)##. So we can write the LT immediately as
[tex]L(s) = \frac{3}{s^2} e^{-s} + \frac{2}{s} e^{-s}[/tex]
Somehow you lost the factor '2' in the last term. Look carefully at what you did and you ought to be able to spot the error.
Whatever you do, try to stop "overthinking" the problem because it really is very simple: wherever you see ##h(t-a) u(t-a)##, its LT will be ##e^{-as} {\cal H}(s)##, where ##{\cal H}(s)## is the LT of ##h(t)##. So, ##(3t-1) u(t-1) = h(t-1) u(t-1)##, where ##h(t) = 3t + 2##.
Thanks for all the help. It makes a lot more sense now.
