Laplacian in toroidal coordinates
  • Context: Graduate
  • Thread starter Thread starter Einj
    Coordinates Laplacian
The discussion focuses on deriving the Laplacian operator in toroidal coordinates defined by the equations \(x=(R+r\cos\phi)\cos\theta\), \(y=(R+r\cos\phi)\sin\theta\), and \(z=r\sin\phi\). Key insights include the necessity of ensuring orthogonality of basis vectors and the importance of differentiating these vectors when computing the Laplacian. The conversation also highlights the use of non-orthogonal coordinate systems, such as flux coordinates in magnet fusion research, which can simplify certain analytical problems.
  • Understanding of Laplacian operator in vector calculus
  • Familiarity with toroidal coordinates and their mathematical representation
  • Knowledge of gradient operators in various coordinate systems
  • Basic concepts of metric tensors and their role in coordinate transformations
  • Study the derivation of the Laplacian in spherical coordinates
  • Learn about the properties and applications of metric tensors in differential geometry
  • Explore the use of flux coordinates in magnet fusion research
  • Investigate the implications of non-orthogonal coordinate systems in physical applications
Mathematicians, physicists, and engineers working with differential equations, particularly those involved in fluid dynamics, electromagnetism, and plasma physics.
Einj
Hi everyone,
I would like to write the Laplacian operator in toroidal coordinate given by:
\begin{cases}
x=(R+r\cos\phi)\cos\theta \\
y=(R+r\cos\phi)\sin\theta \\
z=r\sin\phi
\end{cases}
where r and R are fixed.
How do I do?
More generally how do I find the Laplacian under a generic change of variables?
Thanks
1. For more general coordinates, one of the less obvious features we want to ensure is that the new basis vectors are orthogonal, not just linearly independent of each other. It can be quite difficult to find such a base!
See:
https://en.wikipedia.org/wiki/Toroidal_coordinates
2. In general, the gradient operator in an arbitrary coordinate system will have a scaling factor dependent on the variables, connected to each partial derivative.
For example, we have the spherical gradient operator written as:
\nabla=\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\theta} \frac{\partial}{r\sin\phi\partial{\theta}} +\vec{i}_{\phi}\frac{\partial}{r\partial\phi}
Note that the "denominators" here represents the typical arc-lengths associated with a change in the relevant variable. That is a general feature with the gradient operator in any coordinate system.
The Laplacian operator can be seen as the dot product between the gradient operator with itself, but it is critical then to also differentiate the basis vectors, prior to the "dotting process"
Ok, I get that. I basically write down the metric tensor and so I get my denominators. Now I am a bit confused on how to go from the gradient to the laplacian. In particular, since the basis vectors are no more constant in space I am confused on how to derivate them when we compute \nabla\cdot\nabla.
Here's an example with cylindrical coordinates:
We may split up this in three terms to be summed:
\vec{i}_{r}\frac{\partial}{\partial{r}}\cdot{(\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\theta} \frac{\partial}{r\partial{theta}}+\vec{i}_{z}\frac{\partial}{\partial{z}})}
\vec{i}_{z}\frac{\partial}{\partial{z}}\cdot{(\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\theta} \frac{\partial}{r\partial{\theta}}+\vec{i}_{z}\frac{\partial}{\partial{z}})}
\vec{i}_{\theta} \frac{\partial}{r\partial{\theta}}\cdot{(\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{theta} \frac{\partial}{r\partial{theta}}+\vec{i}_{z} \frac{\partial}{\partial{z}})}
Now, the two first lines don't present any trouble, because the basis vectors only depend on the angle, not on either r or z! Furthermore, orthogonality ensures that most of the the vector dot products are zero, and the two expressions yield the contribution to the Laplacian:
\frac{\partial^{2}}{\partial{r^{2}}}+\frac{\partial^{2}}{\partial{z^{2}}}
The last line in the three major terms are much nastier, because the polar basis vectors DO depend on on the angle!
In particular, we see we get the contribution (PRIOR to dotting!) from \frac{\partial\vec{i}_{r}}{r\partial\theta}=\frac{1}{r}\vec{i}_{\theta}
Collecting the non-zero terms when dotted with the angular basis vector yields us the final two contributions to the Laplacian:
\frac{\partial^{2}}{r^2\partial{\theta^{2}}}+\frac{1}{r}\frac{\partial}{\partial{r}}
The same process is valid for any computation of the laplacian
This isn't true. Yes orthogonal coordinates are nice and simpler to work with, but they aren't always the best choice. In Magnet fusion research we often use coordinate systems based off of the equilibrium magnetic field. This "flux coordinate" systems are a generalization a the simple toroidal coordinate system mentioned, are are often non-orthogonal. The use of flux coordinate systems makes many problems analytically tractable.
Cool!
:smile:
Giving it one more thought:
Defining coordinates "naturally occurring" in a particular area of study, rather than the abstract nicety condition of orthogonality would often be the simplest for analysis.
  • · Replies 29 ·
