Why Does the Laplacian of 1/Vector r Equal Zero?
  • Thread starter Thread starter NewtonApple
    Laplacian Vector
The discussion centers on the mathematical expression for the Laplacian of the function 1/|r|, where r is a vector. Participants clarify that the original problem may contain a misprint, as dividing by a vector (1/vec{r}) is nonsensical. The correct interpretation is to compute the Laplacian of 1/|r|, which is confirmed to equal zero except at the origin (r=0). There are also concerns regarding potential misprints in other parts of the problem, suggesting a need for careful interpretation of the expressions. Overall, the conclusion is that the Laplacian of 1/|r| is indeed zero in the specified context.
NewtonApple
Show that \nabla^{2}\left(\frac{1}{\overrightarrow{r}}\right)=0
Let \nabla=\hat{i}\frac{\partial}{\partial x}+\hat{j}\frac{\partial}{\partial y}+\hat{k}\frac{\partial}{\partial z}
and \overrightarrow{r}=x\hat{i}+y\hat{j}+z\hat{k}, \mid r\mid=\sqrt{x^{2}+y^{2}+z^{2}},
\hat{r}=\hat{i}+\hat{j}+\hat{k}
First calculate \nabla\left(\frac{1}{\overrightarrow{r}}\right)=\nabla\left(\frac{1}{\mid r\mid\hat{r}}\right)=\nabla\left(\frac{1}{\mid r\mid}\hat{r}\right)=\left[\hat{i}\frac{\partial}{\partial x}+\hat{j}\frac{\partial}{\partial y}+\hat{k}\frac{\partial}{\partial z}\right]\left[\frac{\hat{i}+\hat{j}+\hat{k}}{\sqrt{x^{2}+y^{2}+z^{2}}}\right]
= \hat{i}\frac{\partial}{\partial x}\left(x^{2}+y^{2}+z^{2}\right)^{\frac{-1}{2}}+\hat{j}\frac{\partial}{\partial y}\left(x^{2}+y^{2}+z^{2}\right)^{\frac{-1}{2}}+\hat{k}\frac{\partial}{\partial z}\left(x^{2}+y^{2}+z^{2}\right)^{\frac{-1}{2}}
Am I doing it the right way?
##\frac{1}{\vec{r}}## doesn't make sense because it involves dividing by a vector.
Are you sure you aren't supposed to take the Laplacian of ##\frac{1}{|\vec{r}|}## instead?
It looks like a vector
The problem is from Mathematical Methods for Physicists by Tai L. Chow.
You're right, it does look like ##1/\vec{r}##. I think it must be a misprint. It does turn out that ##\nabla^2(1/r)=0## (except at ##r = 0##).
So, I'm thinking that's what was meant.
Part (c) also seems to have some misprints, unless the author is purposely trying to test whether you can tell if an expression is meaningless.
