Larmor Frequency of 57Fe the earth's ambient magnetic field
The Larmor frequency of 57Fe in the Earth's ambient magnetic field can be calculated using the formula f = (γ / 2π)B, where γ is the gyromagnetic ratio (0.8661 x 107 rad T-1 s-1) and B is the magnetic field strength. The calculated frequency based on the total magnetic field strength of 53,222.9 nT is 73.365 Hz, while using the vertical component of 48,890.4 nT yields 67.393 Hz. The published frequency of 3.231 MHz at 2.3488 T shows a discrepancy of 6.68 kHz when compared to the calculated value. All components of the magnetic field, including horizontal, north, east, and vertical, contribute to the total field strength.
  • Understanding of Larmor frequency calculations
  • Familiarity with gyromagnetic ratios
  • Knowledge of magnetic field components and their measurements
  • Basic proficiency in physics and nuclear properties of isotopes
  • Research the implications of magnetic field components on Larmor frequency calculations
  • Explore the relationship between nuclear magnetic resonance (NMR) and Larmor frequency
  • Study the effects of varying magnetic field strengths on frequency calculations
  • Investigate practical applications of Larmor frequency in spectroscopy and imaging
Physicists, nuclear scientists, and researchers interested in magnetic resonance phenomena and the behavior of isotopes in magnetic fields.
rj_duff
I would like to determine the Larmor frequency of 57Fe in the Earth's ambient magnetic field.
Properties \ Nuclide 57Fe
Nuclear Spin, I 1/2
Nuclear magnetic moment, µ +0.09044
Gyromagnetic Ratio (rad T-1 s-1) 0.8661 x 10 7
Quadrupole moment (m2) 0
Relative Sensitivity (1) 3.37 x 10 -5
Natural Abundance, % 2.1
Half-life,T1/2 stable
Absolute Sensitivity (2) 4.2 x 10 -3
Frequency (MHz) @ 2.3488 T 3.231
There is of course an North/South, East/West, and Vertical component which makeup the total magnetic field strength.
1. How would I calculate the Larmor frequency?
2. Do all the magnetic field components need to be accounted for?
I have found related pages on hyperphysics.com but do not have the background to follow everything presented, therefore, unable to determine the values to plug into the formulas.
Any help would be greatly appreciated.
Ok - I'll answer my own question.
f=\frac{\gamma}{2\pi}B
Checking this formula against the above published frequency of 3.231MHz in a 2.3488T field:
(0.8661E7 / 2pi) * 2.3488 = 3.2377 MHz
The results are not in exact agreement - off by 6.68 KHz
Magnetic Field Values
Horizontal Intensity: 21,033.4nT
North Component: 20,753.7nT
East Component: 3418.7nT
Vertical Component: 48,890.4nT
Total Field: 53,222.9 nT
Calculating frequency based on the total field component:
(0.8661E7 / 2pi) * 53,222.9 = 73.365 Hz
Calculating frequency based on the vertical field component:
(0.8661E7 / 2pi) * 48,890.4nT = 67.393 Hz
From a practical standpoint, there is not that much variation in using the
vertical Vs total field component.
  • · Replies 23 ·
