What Is the Laurent Series for e^(1/z)?
The discussion focuses on the classification of singularities for the function e^(1/z) and the derivation of its Laurent series. It is established that e^(1/z) has an essential singularity at z=0, as indicated by the presence of infinitely many negative powers in its Laurent series expansion. The series is expressed as f(z) = 1 - (1/z) + (1/2!) * (1/z^2) + ..., confirming the essential nature of the singularity. Participants clarify the conditions for removable and non-essential singularities, reinforcing the understanding of the function's behavior near z=0.
  • Understanding of complex analysis concepts, particularly singularities.
  • Familiarity with the definition and properties of Laurent series.
  • Knowledge of exponential functions and their series expansions.
  • Ability to analyze the behavior of functions near singular points.
  • Study the properties of essential singularities in complex analysis.
  • Learn about the derivation and application of Laurent series in various functions.
  • Explore the classification of singularities in complex functions.
  • Investigate the implications of singularities on function behavior and limits.
Students and professionals in mathematics, particularly those focusing on complex analysis, as well as anyone interested in understanding the behavior of functions with singularities.
Physgeek64
Cassify the singularities of e^\frac{1}{z} and find the Laurent series
e^\frac{1}{x}=\sum \frac{(\frac{1}{x})^n}{n!}
there's a singularity at z=0, but I need to find the order of the pole
So using the general expression for the expansion of an exponential:
e^\frac{1}{z}=\sum \frac{(\frac{1}{z})^n}{n!} but this leads to a 1 as the first term, which is obviously not consistent.
I also tried considering re-defining a new variable for \frac{1}{z}, but I'm not really sure how to proceed from here
Many thanks :)
If the order of the pole for f(z) at z=0 is n, then that means that f(z) \propto \frac{1}{z^n} near z=0, which in turn means that z^n f(n) remains finite as z \rightarrow 0. So in the case of e^{\frac{1}{z}}, do you think there is some number n that would work?
Im sorry I don't see how you concluded that f(z) \propto \frac{1}{z^n} near z=0, since would the expansion for f(z) =1-\frac{1}{z}+\frac{1}{2!} \frac{1}{z^2}+...
Thank you :)
Steven didn't conclude it. He wrote If ... then ... !
Let me quote from Wikipedia (https://en.wikipedia.org/wiki/Singularity_(mathematics)#Complex_analysis)
  • The point a is a removable singularity of f if there exists a holomorphic function g defined on all of U such that f(z) = g(z) for all z in U \ {a}. The function g is a continuous replacement for the function f.
  • The point a is a pole or non-essential singularity of f if there exists a holomorphic function g defined on U with g(a) nonzero, and a natural number n such that f(z) = g(z) / (za)n for all z in U \ {a}. The number n here is called the order of the pole. The derivative at a non-essential singularity itself has a non-essential singularity, with n increased by 1 (except if n is 0 so that the singularities are removable).
  • The point a is an essential singularity of f if it is neither a removable singularity nor a pole. The point a is an essential singularity if and only if the Laurent series has infinitely many powers of negative degree.
Thank you :)
Ah okay, so in this case we have an essential singularity?
Would I be okay in thinking that the Laurent series is f(z) =1-\frac{1}{z}+\frac{1}{2!} \frac{1}{z^2}+... ? Or have I oversimplified the problem
Thank you :)
My mistake, I misinterpreted his response. Thank you for clarifying :)
