Law of Conservation of Energy Question
The discussion centers on a physics problem involving a 10.0 kg mass sliding down a frictionless inclined plane from a height of 0.500 m and compressing a spring with a force constant of 100.0 N/m. The key equation used is the conservation of mechanical energy: KE (initial) + PE (initial) = KE (final) + PE (final). The final compression of the spring is calculated to be approximately 0.99 m, confirming that the gravitational potential energy converts entirely into kinetic energy before being stored as elastic potential energy in the spring.
  • Understanding of gravitational potential energy (PE = mgh)
  • Familiarity with kinetic energy (KE = 1/2 mv^2)
  • Knowledge of Hooke's Law for springs (F = kx)
  • Concept of conservation of mechanical energy
  • Review the principles of conservation of energy in mechanical systems
  • Learn how to apply Hooke's Law in various spring problems
  • Explore the effects of friction on energy conservation in real-world scenarios
  • Study the dynamics of inclined planes and their impact on motion
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to clarify concepts related to potential and kinetic energy transformations.
kylepetten
A 10.0 kg mass slides from rest down a frictionless inclined plane from a height of 0.500 m. After traveling 5.0 m along the ramp, it moves along a horizontal surface (frictionless again) where it makes contact with a spring. The force constant of the spring is 100.0 N/m. Determine the distance that the spring is compressed before the mass comes momentarily to a halt.
m=10.0 kg
k=100.0 N/m
h=0.500 m
{Initial} [1/2(m)(v^2)]+[1/2(k)(x^2)] = {Final} [1/2(m)(v^2)]+[1/2(k)(x^2)]
That's all I could do. I do not know if I have the correct equation here. But, if I do, I do not know how to get the (v^2) in the equation.
Also, another thing that is troubling me is that I do not know what effect the incline has on the question, or if it does at all.
Thanks, in advance, for your help!
Here the inclined plane is used to accelerate the mass.
Find
KE (initial) + PE (initial) = KE (final) + PE (final). That will give you the final KE of the mass when it starts moving on the horizontal surface.
Again using the conservation of energy, you find the compression in the spring.
You forgot about gravitational PE.
Take your initial point to be when the mass is first released (what's its speed then?) and the final point to be when the spring is maximally compressed (what's its speed then?).
It's the height of the mass at the start that matters. That's 0.500m
Work out the PE. This is converted totally to KE as it slides down the frictionless track.
There is no need to find its velocity, though!
All this KE is then converted into the elastic PE in the spring.
the block starts from rest (so it is not moving), then it has no kinetic energy, but it has gravitational potential energy. as it falls down , it gains kinetic energy, but since the total mechanical energy is conserved in this system, the gravitational potential energy starts reducing at the same rate (same as the gain of kinetic energy). Also, it loses gravitational potential energy simply because it is falling down. Then, it gains potential energy again as it gets in contact with the spring
So, how about this:
[0] + [(10 kg)(9.8)(0.5 m)] = [1/2(10 kg)(0^2)] = [1/2(100 N/m)(x^2)]
0 + 49 = 0 + [50(x^2)]
x= {sqrt[49/50]}
x= 0.99m
Did I do this right?
Thanks for all the replies by the way!
Yes. Perfect!
Doc Al said:
Yes. Perfect!
Thanks very very much!
  • · Replies 20 ·
  • · Replies 21 ·
