Laying on the beach while sunseting question
  • Thread starter Thread starter djkinney
The discussion revolves around calculating the radius of a hypothetical planet based on the time it takes for the sun to set as observed from a height of 1.58 meters. The elapsed time of 10.9 seconds is used to derive the angle of the sun's descent, which is calculated as approximately 0.0454 degrees. The correct formula to find the radius (R) is established as R = 1.58 * cos(angle) / (1 - cos(angle)), leading to a final radius of approximately 5,029,238 meters, with a recommendation to round to 5,000,000 meters due to potential roundoff errors.
  • Understanding of trigonometric functions, specifically cosine.
  • Familiarity with angular measurements and conversions.
  • Basic knowledge of physics related to motion and celestial observations.
  • Proficiency in algebraic manipulation and solving equations.
  • Study the derivation of angles in circular motion using trigonometric identities.
  • Learn about Taylor series expansions for approximating trigonometric functions.
  • Explore the implications of roundoff errors in numerical calculations.
  • Investigate the relationship between height and angle in celestial observations.
Students in physics or mathematics, educators teaching celestial mechanics, and anyone interested in solving problems related to planetary geometry and observational astronomy.
djkinney
Suppose that, while lying on a beach near the equator of a far-off planet watching the sun set over a calm ocean, you start a stopwatch just as the top of the sun disappears. You then stand, elevating your eyes by a height H = 1.58 m, and stop the watch when the top of the sun again disappears. If the elapsed time is t = 10.9 s, what is the radius r of the planet to two significant figures? Notice that duration of a solar day at the far-off planet is the same that is on Earth.
86400 s=1 day
I attempted to solve this by setting the angle, but I think I got the wrong angle. (.0454°)
cos(0.0454°)=((r)/(r+h)) h=1.58
When I solved for the radius I got 1.5e^3, but it is not the right answer. Please help me figure where I went wrong! Thank you!
Hi djkinney,
how did you get the angle?
ehild
ehild said:
Hi djkinney,
ehild
Hey,
Well I'm not quite sure as to how to get the angle. I tried two different ways so far: First, I tried: 10.9s/86400s=1.26e-4°. The second was me trying something crazy and doesn't make any sense: 10.9s*(1min/60s)*(1hr/60min)*(360/24hr)=.0454°
djkinney said:
Hey,
The first method will be all right, but it is not degrees. 1.26e-4 is the ratio to the total revolution, which corresponds to 360 degrees.
ehild
ehild
Okay, so that means that 1.26E^-4*360°=.04536° for the angle? Then I would still be getting my final answer as 1.5E^3
Well, what is that angle and how is it related to the radius of the planet and your height?
ehild
Cos(Angle) = R/(R+1.58)
Angle = 360 * 10.9/(24 * 60 * 60)
Okay, so when I solve for the angle I get .0454°
Then take the cos of the angle in which I get ≈ .9897
Then I set that equal to R/(R+h) h=1.58 → .9897=R/(R+1.58)
Solve for R by multiplying .9897(R+1.58)=R
Then get like terms of one side 1.59=R-R(.9897)
A R can be taken out 1.59=R(1-.9897)
Then I divide 1.59/(1-.9897)=R
R=154m
Is this the correct setup?
I get
R = 1.58 Cos(Angle) / (1-cos(angle))
I make Cos(angle) = 0.9999996858
and
R= 5,029,238 meters
The answer is error prone because the denominator involves subtracting two similar numbers. Might be best to give an answer such as approx 5,000,000 meters?
CWatters said:
I get
and
R= 5,029,238 meters
Wow, I would've never done that. Even my calculus professor didn't tell me that. Thank you so much guys for your help!
Tip: It's usually a mistake to substitute actual values given in the problem until you have rearranged the equations.
The steps I did were..
Cos(angle) = R/(R+1.58)
Cos(angle) * (R+1.58) = R
R*Cos(angle) + 1.58*Cos(angle) = R
1.58*Cos(angle) = R - R*Cos(angle)
1.58*Cos(angle) = R (1 - Cos(angle))
R = 1.58*Cos(angle) / (1 - Cos(angle))
but there might be a shorter way!
I then put the result of Cos(360*10.9/24*60*60) in the memory of the calculator to preserve as many digits as possible while calculating the actual result.
The problems with roundoff error can be removed by using a Taylor series expansion:
1-cosθ ~ θ2/2
I have no preference about length of finding a solution as long as it's the correct one. Thank you so much once again!
25K
10K
9K
  • · Replies 37 ·
