Lead vs. Rubber Bullets: Which is More Effective in Stopping a Bear?
The discussion revolves around the effectiveness of lead versus rubber bullets in stopping a bear, focusing on the implications of momentum, penetration, and impact. Participants explore theoretical and practical aspects of bullet behavior upon impact with a bear.
  • Some participants argue that lead bullets are more effective because they do not compress upon impact, while rubber bullets do.
  • Others suggest that the rubber bullet's ability to rebound could affect its momentum transfer, raising questions about the implications of negative momentum.
  • A participant points out that a rubber bullet of the same size as a lead bullet has less mass and therefore less momentum at the same speed, complicating practical comparisons.
  • Concerns are raised about the deformation of the bear's outer layers by rubber bullets and the potential for shock damage from lead bullets.
  • Some participants propose that the effectiveness of a bullet in stopping a bear may depend on various factors, including the bullet's mass, speed, and the bear's size.
  • A later reply introduces calculations regarding the momentum of different bullet weights and speeds, suggesting that a heavier rubber bullet traveling slower may not effectively stop a bear.
Participants express differing views on the effectiveness of lead versus rubber bullets, with no consensus reached on which is definitively more effective in stopping a bear. The discussion remains unresolved with multiple competing perspectives.
Participants note that assumptions about mass and speed significantly affect the discussion, and practical factors such as bullet design and real-world performance are acknowledged but not fully resolved.
Muhammad Danish
Which bullet of same momentum is more effective in knocking a bear down? Lead bullet or rubber bullet?
What do you think, and why?
Lead bullet, because it will not compress on hitting the bear whereas rubber bullet will compress..
I think it's a matter of the rubber bullet not only compressing but rebounding slightly whereas the lead bullet will put all of its momentum into the bear.
These explanations confuse me:
You phrased the question correctly. But you should be aware that a rubber bullet the same size as a lead bullet has less mass, thus less momentum at the same speed. Also, rubber bullets usually have smaller powder charges than lead bullets.
So if your question is purely theoretical about momentum conservation, you're correct. If your question is practical, about real bullets, then there are more factors.
Careful here guys; if this is theoretical and the mass is the same and the rubber bullet bounces, then its final momentum is negative, not positive and the momentum transfer therefore is...
The explanation in post #5 suggests that the sign of the result is irrelevant. It is the magnitude of the momentum transfer which matters. That explanation plays pretty fast and loose with signs, but as long as you plug speeds in where velocities are called for, it gets the magnitude of the result right.
Would it not be necessary to take into account the fact that the rubber bullet deforms the bears outer layers, which spring back, but the bullet drives a shock deeper into the body and there's little to no bounce-back. I realize I might not be thinking this through properly, so this is not a rhetorical question.
It appears that the intended result is that the lead bullet passes through the bear while the (larger, more massive, less dense, lower velocity, lower energy but same momentum) rubber bullet fails to penetrate and ultimately bounces back.
Oh, well under that assumption I don't see how there can be any question that the rubber bullet has more body impact, but that's not the assumption I would make. Bear are big damn things.
Well yes. The momentum of the projectile is not the thing that will successfully stop a charging bear.
Actually, I hadn't read the embedded photo explanation, but it appears I was pretty close. I had the real bullet embedding, but embed or pass through, it still imparts less momentum than an equal mass and speed rubber bullet that bounces back.
Isn’t it true that the shock damage is greater from a high velocity low mass bullet?
Not sure exactly constitutes ‘stopping’.
(Just to throw in another idea.)
I suspect they meant to add that both lead and rubber bullet had same mass an velocity.
Let us assume that the lead bullet has a typical lead bullet weight of 150 to 300 grains (7000 grains = 1 pound), and further assume that it is traveling at typical lead bullet speed of 2000 to 3000 feet per second. The rubber bullet has the same momentum, so it can be of similar weight traveling at similar speed, or it can be much heavier and traveling at lower speed.
If the rubber bullet has the same weight and speed as the lead bullet, it will penetrate the bear and not bounce back.
If the rubber bullet is much heavier than the lead bullet, it's time for a calculation. Assume a 250 grain bullet at 2500 feet per second, a combination that is about right for bear hunting. The momentum is 2.77 lb-sec. A 10 pound rubber bullet with the same momentum would be traveling 9 feet per second, or 6 miles per hour. It would bounce off, and the bear would probably not even notice.
Neither bullet will "knock the bear down", although the lead bullet is certainly capable of killing and dropping the bear.
And hunting bullets are made from a copper alloy, typically with a lead core.
  • · Replies 34 ·
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 17 ·
