Question about transfer of Energy and Momentum in Ballistics
The discussion revolves around the mechanics of energy and momentum transfer when a projectile strikes a person wearing bulletproof armor. Participants explore the reasons why a person does not get knocked down by a bullet despite the high energy involved, comparing it to the effects of a punch. The conversation includes theoretical considerations and mechanical explanations related to ballistics and impact dynamics.
  • Some participants suggest that the energy from a bullet is dissipated through the deformation of the armor, which may prevent the person from being knocked down.
  • Others argue that momentum is the critical factor in determining whether someone is knocked down, indicating that a bullet has lower momentum compared to a punch.
  • It is proposed that the ability to react to an incoming punch allows a person to minimize injury, while a bullet's impact is sudden and less predictable.
  • Some participants note that energy alone does not impart a "push," and that the conservation of momentum plays a significant role in the dynamics of the impact.
  • A later reply questions the role of energy in the impact, asking what happens to the energy if it does not contribute to knocking someone down.
  • There is mention of the complexities involved in calculating the final velocity of the target and the energy lost to deformation and heat generation.
Participants express differing views on whether energy transfer or momentum is more relevant to the question of why a person is not knocked down by a bullet. The discussion remains unresolved, with multiple competing perspectives on the mechanics involved.
Participants acknowledge that the discussion is complicated by the fictional portrayals of ballistic impacts in media, which do not adhere to physical laws. There are also uncertainties regarding the exact amount of energy lost during impact and the specifics of how armor interacts with projectiles.
This discussion may be of interest to those studying physics, engineering, or ballistics, as well as individuals curious about the mechanics of impact and energy transfer in high-velocity scenarios.
  • #31
Filip Larsen said:
You still seem to mix energy and momentum a bit. You should consider energy and momentum as two independent quantities that "just happens" to be related via mass and velocity. The momentum of the bullet (minus loss during flight) is transferred from the shooter to the target and, independently of this, some part of the energy released by the gun powder is first transferred to the bullet in the barrel and then transferred (except for loss during flight) to the target.
I think this was my misconception. It was my understanding that any motion undertaken by an object is a byproduct of energy and thus must be caused by energy. So the transfer of momentum causes the object to move accordingly, not the transfer of kinetic energy, and even though the kinetic energy transfer isn't zero (because kinetic energy and momentum both are a product of mass and velocity), the energy is not the cause of motion. Am I still misunderstanding?
So, then, how does work fit in?
  • #32
Movement requires BOTH energy and momentum. Your misunderstanding, in my opinion, centers around the idea that motion is related to one more fundamentally than the other. This is not true. Both are equally fundamental, they just behave and are transferred somewhat differently. Neither is the cause of motion.
  • #33
Assaltwaffle said:
I think see now. It seems I had a fundamental misunderstanding about what determined the "impulse" and how what work the bullet did is determined.
So, if the round is fully stopped by a plate or fully capture by a body, the full momentum is transferred as an impulse. Energy does this work and transfers energy accordingly to make that impulse, but the rest of the energy of the projectile is lost through doing "damage", such as bending metal, breaking ceramic, or tearing flesh.
I would say "yes", you have this correct. Some small portion of the kinetic energy of the bullet is expended in the kinetic energy corresponding to the bulk motion of the target body. Energy is conserved. The remaining energy must be accounted for otherwise. As you put it, bending metal, breaking ceramic or tearing flesh. Or is retained as the bullet proceeds on and through the target.
Assaltwaffle said:
If I understand it, it would seem to reason that if the plate failed because it could not resist the projectile and the object passed through the target, that the impulse would be less because the round still had energy and momentum remaining upon exit and did not transfer all of its momentum. Is that correct?
Yes. If the bullet carries on through the target, it retains some of its original momentum. Less has been transferred to the target.
  • #34
To the extend you mean that change in momentum of an isolated object causes change in its velocity, then you are correct. In classical mechanics Newtons 2nd law states that time rate change in momentum for an object equals the net force on that object, so if you can model what forces an object experiences as a function of its position and velocity then you can calculate how the object moves without directly having to consider the energy of anything.
However, for some dynamical models it can be much easier to derive the dynamics considering the energy flow between the interacting parts, especially so when the interactions can be modeled as frictionless. And in some cases, like for fully elastic collisions, you need to consider (conservation of) both momentum and energy at the same time to arrive at a solution.
Another reason why mass, momentum and energy are important (and independent) concepts in classical mechanics is that the sum of each of these quantities for the parts of an isolated system can be considered a conserved quantity (i.e. constant over time), with energy being conserved as the sum of kinetic energy and internal energy in case of friction.
  • #35
Assaltwaffle said:
why, mechanically, is the person not knocked over despite such a high amount of energy striking the individual relative to a weaker force that can achieve this?
You made quite the leap there from energy to force. Just because something has more energy doesn't mean it exerts a larger force. You have to take into account the distance the object moves while it's slowing down.
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 30 ·
