Learning to Write a Recursive Algorithm in Pseudocode
  • Topic:
  • Thread starter evinda
    Algorithm
12 replies · 3K views · last reply
evinda
MHB
Hi! (Wave)
I want to write a recursive algorithm as a pseudocode.
How can I define the function? Which has to be its structure?
evinda said:
Hi! (Wave)
Hey! (Smile)
The standard example is:
Code:
//INPUT: n is an Integer such that n >= 0
int fact(int n)
   if (n == 0)
      return 1;
   else
      return n * fact(n - 1);
The structure is:
  1. a final condition that makes the recursion stop,
  2. a recursive call.
The standard pitfall is that the final condition is not properly set, causing an infinite recursion. :eek:
Code:
int fact(int n)
   if (n == 0)
      return 1;
   else
The structure is:
I am asked to find the maximum of an array.
Do I have to define the function as int or something else? (Thinking)
You can leave out the types, since they won't be relevant for the algorithm. (Mmm)
In my notes, there is this algorithm:
Code:
Index BinarySearch(Type A[0...N-1], Type value, Index low, Index high){
  if (high<low) return -1
  mid=low+(high-low)/2;
  if (A[mid]>value) return  BinarySearch(A, value, low,mid-1);
  else if (A[mid]<value) return  BinarySearch(A, value, mid+1,high);
  else return mid
What does Index represent? (Thinking)
Code:
  else return mid
"Index" is an unspecified type that can be used as an index.
For practical purposes you can assume its an [m]int[/m]. (Nerd)
Btw, it looks more like real C code than pseudo code (except for a couple of syntax errors). (Wait)
What is the difference between Index and Type? What does the latter represent? (Worried)
How could it be otherwise? (Thinking)
Also, at the algorithm, I want to use the floor function.
Can I write it like that: $\lfloor x \rfloor$ or do I have to write it like that: $\text{ floor }(x)$ ? (Thinking)
"Type" is an unspecified type for values that are in the array.
It might for instance be a [m]double[/m]. (Smile)
Well, the following is pseudo code for a binary search algorithm.
It is not C, nor any other actual programming language - it's pseudo code. (Angel)
Code:
function binarySearch(a, value, left, right)
    if right < left
        return not found
    mid := floor((right-left)/2)+left
    if a[mid] = value
        return mid
    if value < a[mid]
        return binarySearch(a, value, left, mid-1)
    else
        return binarySearch(a, value, mid+1, right)
Both are fine.
Pseudo code is only intended to get the idea of an algorithm across.
It does not have to be syntactically correct according to some formal programming language.
It's a sort of free style language. (Party)
Code:
    if right < left
        return not found
    if a[mid] = value
        return mid
    if value < a[mid]
    else
Both are fine.
I understand! Could I also use the and operator like that:
Code:
if (condition1 && condition2)
or is it too C-like? (Wasntme)
Code:
Up to you! (Nod)
Alternatively, you could write:
Code:
if condition1 and condition2
Which do you think is easier to read? (Wondering)
I like Serena said:
Up to you! (Nod)
Code:
I think the second one is easier to read.. Do you agree? (Blush)
Yes. (Angel)
