Does Length Contraction Affect the Wavelength of Light from a Moving Source?
The discussion centers on the effects of length contraction and relativistic Doppler shift on the wavelength of light emitted from a moving source, specifically a spaceship traveling at 0.8c. Observers on Earth perceive the spaceship to contract in its direction of motion, while the emitted light's wavelength is affected by both time dilation and the relative velocity of the source. The observed wavelength is calculated using the formula (c ± v)/(f √(1 - v²/c²)), which differs from the Lorentz contraction factor √(1 - v²/c²). This highlights the distinction between spatial contraction and the relativistic effects on light propagation.
  • Understanding of special relativity concepts, including time dilation and length contraction.
  • Familiarity with the relativistic Doppler shift equation.
  • Basic knowledge of wave properties, specifically frequency and wavelength.
  • Concept of light speed (c) and its implications in relativistic physics.
  • Study the derivation and applications of the relativistic Doppler shift equation.
  • Explore the implications of time dilation on moving observers in special relativity.
  • Investigate the relationship between frequency, wavelength, and the speed of light in different reference frames.
  • Learn about Lorentz transformations and their role in understanding relativistic effects.
Students and professionals in physics, particularly those focusing on special relativity, astrophysicists, and educators seeking to clarify concepts related to the behavior of light from moving sources.
Zero-G
Hey, sorry if this is a stupid question but I'm getting really confused...
If I am standing on the Earth and watch a spaceship moving past at say 0.8*c from left to right, I will observe the spaceship to contract in its direction of motion. If a person on the spaceship shines a torch also from left to right, what happens to the wavelength of the light as seen from my reference frame? Does it also contract?
In the ship's frame, the wave peaks move at c, so the distance between peaks is just c/f, where f is the frequency that the peaks are being emitted by the torch as seen in the ship's frame. In your frame, the peaks still move at c, but the frequency becomes f \sqrt{1 - v^2/c^2} due to time dilation, and meanwhile the torch is moving at velocity v so it will have moved a distance of v / (f \sqrt{1 - v^2/c^2}) between emitting successive peaks, so the the distance between peaks should either be c / (f \sqrt{1 - v^2/c^2}) - v / (f \sqrt{1 - v^2/c^2}) or c / (f \sqrt{1 - v^2/c^2}) + v / (f \sqrt{1 - v^2/c^2}) depending on whether the torch is shining in the direction of the ship's motion or in the opposite direction. This simplifies to (c \pm v)/(f \sqrt{1 - v^2/c^2}). You could also get this from the relativistic doppler shift equation, f_{observed} = f_{emitted} \sqrt{1 - v^2/c^2} / (1 - v/c), keeping in mind that the wavelength you observe is c / f_{observed}.
To compare the wavelength you see with the wavelength seen by the ship-observer, just divide (c \pm v)/(f \sqrt{1 - v^2/c^2}) (the wavelength seen by you) by c/f (the wavelength seen by the ship-observer), which gives (1 \pm v/c) / \sqrt{1 - v^2/c^2} for the factor that the wavelength changes in your frame. This is not the same as the Lorentz contraction factor \sqrt{1 - v^2/c^2}.
  • · Replies 45 ·
  • · Replies 29 ·
  • · Replies 38 ·
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 40 ·
