This was originally posted in "physics" and deleted because there are no "physics" questions in it. I have "undeleted" and moved to "mathematics" because there are so many errors that need to be addressed.
shounakbhatta said:
Hello,
I was going through a article which states as follows:
If we had 2 real vectors like u & v, we would have calculated the length as
√u^2+v^2
You have misread. That is NOT "the length of two real vectors"- in fact,
two real vectors do NOT have a single "length". It is, rather, the length of a single two-dimensional vector ui+ vj.
but in case of a complex vector v = (1 + 2i)ˆi + (3 − 4i)
we calculate
as v.v= (1 + 2i)2 + (3 − 4i)2 = −10 − 20i
My question is why do we multiply v.v, why not using the sqrt.formula?
Thanks,
-- Shounak
The only correct answer is that we
don't. You are mistaken- we do NOT find the length of compex vectors like that. For real numbers, we can define the "absolute value" as |x|= \sqrt{x^2}, a positive real number. For complex numbers that would not be a positive real number so we define, instead, |x|= \sqrt{xx^*} where x^* is the "complex conjugate"- the complex conjugate of the complex number a+ bi is a- bi so that |a+ bi|= \sqrt{(a+ bi)(a- bi)}= \sqrt{a^2+ bi- bi+ b^2}= \sqrt{a^2+ b^2}.
For vectors with complex coefficients, ae1+ be2+ ce^3 where a and b are complex (I have used "e1", "e2", and "e3" as basis vectors rather than "i", "j", and "k" so as not to confuse the basis vector "i" with the imaginary unit, "i"), the length is the square root of the sums of the products of each component and its complex conjugate: \sqrt{aa^*+ bb^*+ cc*}. If a, b, and c happen to be real numbers, then their complex conjugates are the same as a, b, and c themselves and the formulas reduces to the previous \sqrt{a^2+ b^2+ c^2}.
In particular, the example you give, v = (1 + 2i)ˆi + (3 − 4i)^j has length \sqrt{(1+2i)(1- 2i)+ (3- 4i)(3+ 4i)}= \sqrt{1+ 4+ 9+ 16}= \sqrt{30}, a positive real number, NOT what you have.
I recommend you go back and reread that article. Pretty much
nothing you say you read in it is correct.
I recomm
