How Long Does a Pendulum Take to Complete 12 Oscillations?
The discussion focuses on calculating the period of a pendulum and its relationship to oscillations. A 125 g ball is tied to a string and completes 12 oscillations in 9 seconds, leading to a calculated period of 1.33 seconds. The correct formula for the period of a pendulum is T = 2π√(l/g), and it was clarified that mass and angle do not affect the period. Participants also explored a related problem involving the period of a pendulum on Mars, confirming the method used to calculate gravitational acceleration. The conversation emphasizes understanding the fundamental properties of pendulums and their equations.
hellokitty
A 125 g ball is tied to a string. It is pulled to an angle of 4.80 degrees and released to swing as a pendulum. 12 oscillations take 9.00 s.
Please help, I'm not sure which formulas to use
What do you know about pendulums? What's the formula for the period of a pendulum?
Period (T) = 1/f
T = 2π √(l/g)
hellokitty said:
Period (T) = 1/f
That's true, but that's true in general, not just for pendulums. What formula allows you to calculate the period of a pendulum from its physical properties, such as its length?
T = 2π √(l/g)
That's the one.
Hint: Use the data provided to find the period. Then solve for the unknown length.
I did that, but I wasn't sure if I got the correct answer.
T = 12/9 = 1.33333
1.3333=2π√(L/9.8)
1.3333(2π)= √(L/9.8)
squared the left side and multiplied it by 9.8 and..
I eventually got 687.07m
T = 12/9 = 1.33333
Careful. The period is the time for one oscillation, so it should be total time divided by the number of oscillations. (You have them switched.)
ah, I see.
Thanks!
I haven't had any practice in physics for a long time, so I'm trying to re-learn everything.
I just realized that I didn't use the mass or degree of angle in solving the question.
Is there a way to answer this question using another equation?
Perhaps the period does not depend on either of those variables. :wink:
Are there are more parts to this question?
no, this was the entire question.
I guess the mass and angle is there to play mind tricks.
Another question:
Astronauts on the first trip to Mars take along a pendulum that has a period on Earth of 1.50 s. The period on Mars turns out to be 2.45 s.
My answer:
I used the equation T=2pi √ (L/g)
I first plugged in the 1.5s = 2pi √ (L/9.8) and found L = .5585
Then I plugged in 2.45s = 2pi √(.5585/g) to solve for g of mars.
Now I got 3.6733 m/s2 = g for mars.
Can someone correct me if I'm wrong or if there is an easier way to solve this problem?
Yours is a perfectly fine way to solve this problem.
Here's how I would solve it:
T_e = 2\pi \sqrt{L/g_e}
T_m = 2\pi \sqrt{L/g_m}
Divide the two and square:
(T_e/T_m)^2 = g_m/g_e
Thus:
g_m = g_e(T_e/T_m)^2
