Length of sides of a wire loop in a uniform magnetic field
The calculation of the length of the sides of a wire loop in a uniform magnetic field was addressed using the formula ##\tau=NIABsin\theta##. With values ##\tau=0.0727##, ##N=60##, ##i=1.3##, ##B=1.0##, and ##\theta=15##, the correct calculation for side length ##s## was derived as ##s=\sqrt{\frac{\tau}{NIBsin\theta}}=0.0632 m (6.32 cm)##. The initial confusion stemmed from neglecting to take the square root of the result, and a misconfiguration of the calculator's mode (degrees vs. radians) was also identified as a source of error.
  • Understanding of torque in magnetic fields
  • Familiarity with the formula for torque: ##\tau=NIABsin\theta##
  • Basic proficiency in using scientific calculators
  • Knowledge of trigonometric functions and their applications
  • Review the principles of electromagnetism related to torque and magnetic fields
  • Practice calculations involving torque using different values for ##N##, ##i##, ##B##, and ##\theta##
  • Learn about the implications of calculator settings on trigonometric calculations
  • Explore advanced applications of wire loops in magnetic fields, such as in electric motors
Physics students, electrical engineering students, and professionals working with electromagnetic systems will benefit from this discussion.
cestlavie
A wire loop with 60 turns is formed into a square with sides of length 𝑠. The loop is in the presence of a 1.00 T uniform magnetic field 𝐵 that points in the negative 𝑦 direction. The plane of the loop is tilted off the 𝑥-axis by ##\theta=15##. If 𝑖=1.30 A of current flows through the loop and the loop experiences a torque of magnitude 0.0727 N⋅m , what are the lengths of the sides s of the square loop, in centimeters?
## A=x^2##
## \tau=NIABsin\theta##
If ##\tau= 0.0727, N=60, i=1.3, B=1.0,## and ##\theta=15##, I tried the following calculation:
##\tau=NIs^2Bsin\theta##
##s^2=\frac {\tau} {NIBsin\theta}=\frac {.0727} {60*1.3*1*sin(15)}=0.0632 m=6.32 cm##
The answer is probably right in front of me, but I don't know what I am doing wrong.
One thing, the dimensions of the last equation is length squared.
Oops! I forgot to add the square root! But my answer is for s, not s squared.
##s^2= \frac {\tau} {NIBsin\theta}##
##s=\sqrt {\frac {\tau} {NIBsin\theta}}=0.0632m = 6.32 cm##
I feel all kinds of stupid. I tried doing a different set of numbers and realized that my calculator was not in degrees. Thank you @Keith_McClary for your help.
  • · Replies 37 ·
