Lenses/Mirrors, [1/f = (1/do+1/di)] sign help
  • Thread starter Thread starter michaelw
    Sign
The discussion revolves around the sign conventions used in the lens/mirror equation \(1/f = (1/do + 1/di)\). Participants are exploring the definitions and implications of the variables involved, specifically the focal length (f), object distance (do), and image distance (di) in the context of optics.
  • Participants are attempting to clarify the signs associated with f, do, and di for different types of lenses and mirrors. There are discussions about the definitions of real and virtual objects and images, as well as the implications of these definitions on the sign conventions. Some participants suggest using alternative notations (p and q) for clarity.
The conversation is ongoing, with various interpretations of the sign conventions being explored. Some participants have provided diagrams and examples to illustrate their points, while others have expressed confusion and sought further clarification. There is no explicit consensus yet, but the discussion is productive with multiple perspectives being shared.
Participants note that different sign conventions exist, and emphasize the importance of sticking to one convention to avoid confusion in numerical problems. There are also mentions of specific cases, such as multiple lens systems, where the object distance may be treated differently.
michaelw
Hello
Im really confused on the signs for f, do and di in this equation..
Please tell me if I am correct.. but here is how i presently understand if
For definition sake, the 'front' of a mirror is where you would normally stand to look in a mirror, and the 'front' of a lens (like a camera) is where the objects are that you want to take a picture of.
f is (+) for a converging lens/mirror, (-) for diverging. always.
do is (+) when its in the 'front'
di is (+) when it is a real image
is this right?
that's correct. i think it helps to use p and q instead of di, do since i tend to think distance in instead of image and out instead fo object, but maybe that's just me. I've attached a diagram showing where the di and do is positive and negative for lenses and for mirrors since it changes when you're looking at one or the other.
focal point is no problem, as you said.
becareful with do and di.
now, if i use light rays coming from left to right, and the mirror/lens is on the right,
for mirror:
do is positive when object is on the left, in front of mirror, i.e. real object.
do is negative when the object is on the right, behind the mirror, i.e. virtual object.
how can you create virtual object like this? easy. put a real object in fornt of a convex lens and adjust it so that the image falls behind the mirror. this image becomes virtual object of the mirror.
di is positive when image is on the left, in front of mirror, i.e. real image.
di is negative when image is on the right, behind mirror, i.e. virtual image.
in practice, the easiest way to differentiate them is you can always see virtual image directly by your eyes (that's why you see yourself in the mirror).
for lens:
do is + when object is on the left, front of lens, i.e. real object.
do is - when object is on the right, behind lens, i.e. virtual object.
how can you create virtual object? the same as above.
di is + when image is on the right, behind lens, i.e. real image.
di is - when image is on the left, front of lens, i.e. virtual image.
to be even surer, draw the triangles and image formation diagram, and you can see that these convention is extremely consistent no matter how you vary the configuration. try to derive the mirror formula first, very very easy.
if get stuck i may be able to provide drawing ... if i have time.
it's been my experience that the object distance is always positive!
:wink:
for mirrors and lenses combined, there are four possibilities:
1) to the left of the mirror (in the "real image" zone)
2) to the right of the mirror (in the "virtual image" zone*)
3) to the left of the lens
4) to the right of the lens
* option 2 makes absolutely no sense! you can't have an object as a virtual image! that's the friggin' mirror world! :biggrin:
so for mirrors, we have object distance can only take on positive values.
now, for lenses: if the object is to the left of the lens, it's positive. but if the object is to the right of the lens, we can rotate our diagram so that it's back to being on the left side without loss of realism! (a real image formed by a lens would be on the opposite side of the object, etc.)
so for both mirrors and lenses, the object distance is always positive.
my mnemonic for this, when using "p" and "q" is "p is always positive."
Usually! But in a multiple lens problem, when the real image from the first lens becomes the object for the second lens, then the object distance (with respect to the second lens) is negative.
ah!
i didn't consider multiple lens problems.
touche!
thanks guys
just to be sure again (replies may have confused me lol)
do is (+) when its in the 'front', always
di is (+) when it is a real image, always
the front of a mirror is where you stand to look in the mirror (there is no back)
the back of a camera (lens) is where you stand to take a picture of something
A number of sign conventions are there. One is Real Positive, in which real distances are taken positive and virtual distances are considered negative whatever may be the side, front or back.
In the other the Object distance is taken positive and yet one more in which the object distance is considered negative.
You have to stick to one of those conventions otherwise may get Problems with the numerical problems.
I prefere the sign convention, which is corelated with coordinet geometry. According to this convention….
1. The rays are considered to fall on the mirror or lens from left to right. (the diagram shoud be such)
2. All the distances are measured from the pole of the mirror or from the optical center of the lens. [Origin]
3. The distances measured in the direction of incident light are taken as positive [same as +x direction]
4. The distances measured in the direction opposite the direction of incident ray are taken as negative [-x]
5. The heights (of object or image) measured in upper half plane are taken as positive. [+y]
6. The heights measured in lower half plane are taken negative. [-y]
7. The focal length of the converging lens is taken as +ve.
Points to be remembered
a. In case of multiple refractions or reflections the sign is taken accordingly. (Direction of incident rays)
b. Power of a lens Pl = + 1/f
c. Power of a mirror Pm = - 1/f
