Let f, g and h be functions defined below:
  • Thread starter Jaco Viljoen
    Functions
14 replies · 3K views · last reply
Jaco Viljoen
f(x)=(√x^2-3x+2)/(2x-3),
g(x)=3/(√(x+3)) and
h(x)=(x^2-5x+6)/(x-2)
which of the following are true:
A)Df={x∈ℝ:x≤1 or x≥2}
B)Dg={x∈ℝ:x≥-3}
C)Dh=ℝ
I am using substitution here by replacing the x by the parameters specified and slightly further:
Df={x∈ℝ:x≤1 or x≥2}
f(x)=(√(0^2-3(0)+2))/(2(0)-3) (yes this is ok)
f(x)=(√(1^2-3(1)+2))/(2(1)-3) (yes this is ok)
f(x)=(√(-1^2-3(-1)+2))/(2(-1)-3) (yes this is ok)
f(x)=(√(2^2-3(2)+2))/(2(2)-3) (yes this is ok)
f(x)=(√(3^2-3(3)+2))/(232)-3) (yes this is ok)
Dg={x∈ℝ:x≥-3}
g(x)=3/(√(-3+3)) gets 3/0 Undefined?
g(x)=3/(√(-2+3)) (yes this is ok)
Dh=ℝ
h(x)=(1^2-5(1)+6)/(1-2) (yes this is ok)
h(x)=(2^2-5(2)+6)/(2-2) (yes this is ok)
So my answer would be:
A and C are true.
Your answers are correct.
[EDIT:-however your reasoning for ##h(x)## is wrong. 2^2-2*5+6/(2-2)=0/0, which is indeterminate.
HINT:-factorize the numerator of ##h(x)## to see why your answer is correct nonetheless.]
0/0 is just 0 isn't it?
No. 0/0 is indeterminate. The previous post was for a post that I think you deleted?
So wouldn't only A be correct/true,
Factorise
h(x)=(2^2-5(2)+6)=(4-10+6)=0
I don't think I understand...
Factorise
C is also correct.
Factorize ##x^2-5x+6##, then see if anything changes in ##h(x)## because of that.
C)Dh=ℝ
Dh=ℝ
No, the above should be h(1). h(x) = ##\frac{x^2 - 5x + 6}{x - 2}##
This (above) should be h(2), which is NOT OK. As certainly said, this results in the indeterminate form 0/0, which should suggest that 2 is not in the domain of h.
A and C are true.
Mark,
so is it only A?
Certainly agrees with my initial answer, but I am not sure why?
He has asked me to factor as above, I have but still not clear why?
Jaco Viljoen said:
Mark,
so is it only A?
Write the formula for h(x) in factored form. IOW,
$$h(x) = \frac{(?)(?)}{x - 2}$$
In the factored form it is easier to see that for some value(s) of x, both the numerator and denominator are zero. This means that at any such value, the function h is not defined, so the domain is not all of R (the reals).
(x-3)(x-2)
if x is 2 or 3 it will be zero,
but how can 0/0 undefined = ℝ?
Jaco Viljoen said:
(x-3)(x-2)
The full answer to my question is: ##h(x) = \frac{(x-3)(x-2)}{x - 2}##
h(3) = 0/1 = 0
h(2) is not zero. Since division by zero is not defined, 2 is not in the domain of h.
0/0 is not a number -- it is one of several indeterminate forms. These usually show up as limits, which I'm pretty sure you haven't covered yet.
I was a bit confused there about something, Mark is right, the domain is all of ##\mathbb{R}## except 2, so yeah, C is wrong.
Jaco Viljoen said:
Dh=ℝ
When determining the domain here, you don't need to look at what the numerator is equal to. You simply have to note that the denominator is 0 when x=2, so h isn't defined for x=2. Division by 0 is always undefined.
