Let's Make a Deal Event: Odds of Switching for a Win
  • Context: Undergrad
  • Thread starter Thread starter matt010nj
The discussion revolves around the "Let's Make a Deal" problem, commonly known as the Monty Hall problem. Participants explore the probabilities involved in switching choices after one option is revealed to contain a goat, questioning the reasoning behind the claim that switching doors increases the likelihood of winning the car.
  • One participant expresses confusion about why switching doors is advantageous, believing it seems like a 50/50 chance after one door is revealed.
  • Another participant argues that the probability of having initially chosen the correct door is 1/3, while switching leads to a 2/3 chance of winning, given that a goat is revealed.
  • A participant suggests using a paper analogy to visualize the problem, reinforcing the idea that switching is beneficial.
  • Another participant introduces a hypothetical scenario with a million doors to illustrate the concept of probability in a more extreme case.
  • Some participants reference the Monty Hall problem as a well-known paradox, indicating its established status in discussions of probability.
  • One participant draws a comparison between the Monty Hall problem and the paradox of the hare and the turtle, suggesting a misunderstanding of the underlying mathematical principles.
  • Another participant challenges this analogy, asserting that the two scenarios are not related, emphasizing the importance of understanding the event as a whole.
  • A participant notes that the host's actions (not opening the winning door) introduce a bias in the probability of winning based on the choice to switch.
Participants express differing views on the interpretation of the problem and the validity of the switching strategy. While some support the idea that switching increases the chances of winning, others remain skeptical and question the reasoning behind it. The discussion does not reach a consensus.
Participants highlight the importance of understanding the problem as a whole event rather than as isolated choices, indicating potential limitations in their reasoning. There is also a noted confusion regarding the relationship between the Monty Hall problem and other probability scenarios.
matt010nj
what explanation stands behind "let's make a deal"'s evenement? As i remember there are 3 doors : one with a car behind,and two with goats. After you choose 1 of three doors - they show you one door where there is a goat ,than give you a chance to switch the door and - as my friend claims - you should always switch a door because of the odds but he only read that in some article and can't explain.
How is it more probable that the "switch" is correct choice since it seems 50% chance that you have the right door already?
The only explanation I can see is that you already had one chance and you guessed "right" not taking the one witch the goat they show you , but the switch alone looks still as a fresh 50/50 to me... :(
Matt
You just have to see that problem the right way. 1/3 of the time, you have already made the correct choice. But in 2/3 of the cases--since he has shown a goat, switching is to the correct door.
If it really bothers you, you can work it out with pieces of papers. Given three choices A,B,C, just place the correct choice at A 1/3 of the time, similarly at B and C. Then making the same choice on all occasions, say A, pick up the papers from the blank side, and switch. The secret is that the door opened shows a goat.
Does it mean that I need to see it as whole one event in order the switch on the end to be correct choice?Like in poker with a flush draw after the flop- 50/50(but I have to see the river) instead of 25% on turn +25% on river?
matt010nj, I don't understand your question but I have an analogy that might help your intuition...
Suppose that, instead of three doors, you have a million! Only one door out of the million doors has the car. Pick a door, any door! What are the chances that you've won a car?
After you've picked your door, let me help you out by opening 999,998 doors so that there are only two left closed: the door you chose and some other door. None of the 999,998 open doors revealed the car so you know that it must be behind one of the two doors left closed.
Do you want to change your guess?
mathman said:
http://en.wikipedia.org/wiki/Monty_Hall_problem
This is a well known "paradox". Look at the above.
ok I got it now,thanks
:) I Think in reality its similar to paradox about how hare never catches a turtle to whom he gave a head start :)
It has no connection to the hare catching turtle paradox.
why ? it is mathematicly/teoreticly correct but in real world just doesn't work just like turtle/hare(unless we treat it as whole event and ask about "switching" in advance).Am I wrong here?
My thinking is : at the point of choice - switch or not - we have two doors to choose from.
The fact that the host can't open your door and can't open the winning door biases the event
  • · Replies 212 ·
17K
  • · Replies 131 ·
12K
  • · Replies 21 ·
17K
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 32 ·
  • · Replies 38 ·
