What Are Level Lines and Gradients in Multivariable Calculus?
  • Context: MHB
  • Thread starter Thread starter mathmari
    Gradient Lines
The discussion focuses on the analysis of level lines and gradients for the function \( f(x,y) = \frac{x^2-1}{y^2+1} \). It establishes that level lines \( N_c \) can be hyperbolas or ellipses depending on the value of \( c \), with specific parametrizations derived for each case. The gradient \( \nabla f \) is calculated and shown to be orthogonal to the level lines, confirming that the direction of maximum directional derivative occurs along the gradient vector. The discussion concludes with the need to consider parametrizations for all connected components of the level curves.
  • Understanding of multivariable calculus concepts, including level curves and gradients.
  • Familiarity with hyperbolic functions and their properties.
  • Ability to perform implicit differentiation and analyze parametric equations.
  • Knowledge of directional derivatives and their geometric interpretation.
  • Study the properties of hyperbolas and ellipses in the context of level curves.
  • Learn how to compute gradients and directional derivatives for multivariable functions.
  • Explore the implications of the gradient being orthogonal to level curves.
  • Investigate the use of parametrizations in visualizing and analyzing curves in multivariable calculus.
Students and educators in multivariable calculus, mathematicians analyzing level curves, and anyone interested in the geometric interpretation of gradients and directional derivatives.
mathmari
MHB
Hey! :giggle:
We consider the function $f:\mathbb{R}^2\rightarrow \mathbb{R}$ with $$f(x,y)=\frac{x^2-1}{y^2+1}$$
(a) Describe and draw the level lines $N_c$ of $f$ for all $c\in \mathbb{R}$. Determine for each connected component of each non-empty level lines $N_c$ a parametrization $\gamma_c:I\rightarrow \mathbb{R}$.
(b) Calculate the gradient $\nabla f(\gamma_c(t))$ of $f$ in the point $\gamma_c(t)\in \mathbb{R}^2$. Show directly that $\nabla f(\gamma_c(t))$ is orthogonal to the level lines $N_c$ at the point $\gamma_c(t)$.
(c) Let $x\in \mathbb{R}^2$, such that $\nabla f(x)\neq 0$. Determine the direction with maximum directional derivative of $f$ in point $x$.For (a) :
We have that $$f(x,y)=c \Rightarrow \frac{x^2-1}{y^2+1}=c \Rightarrow x^2-1=(y^2+1)c \Rightarrow x^2-cy^2-(c+1)=0$$
If $c=0$ then we have $x^2=1 \Rightarrow x\pm 1$, so we get the lines $x=1$ and $x=-1$.
If $c>0$ we have then $c=m^2>0$. So $x^2-m^2y^2-(m^2+1)=0 \Rightarrow x^2-m^2y^2=(m^2+1)$. We have $B^2-4AC=0-4\cdot 1\cdot (-m^2)=m^2>0$. So it is the general equation of an hyperbola with axes parallel to the coordinate axes.
If $c<0$ we have then $c=-m^2<0$. So $x^2+m^2y^2-(-m^2+1)=0 \Rightarrow x^2+m^2y^2=(-m^2+1)$. The left side is always non-negative, so also the right side must be. So $1-m^2\geq0 \Rightarrow m^2\leq1 \Rightarrow -1\leq -m^2 \Rightarrow -1\leq c$. That means that is $c$ is negative then $c$ must be greater or equal to $-1$. If $-1<c<0$ then we have the general formula of an ellipse. If $c=-1$ then we get $x^2+y^2=0$ which is the point $(0,0)$.
Is that correct?
How do we determine for each connected component of each non-empty level lines $N_c$ a parametrization $\gamma_c:I\rightarrow \mathbb{R}$ ?
:unsure:For (b) :
We have that $$\nabla f(x,y)=\frac{2x}{y^2+1}\hat{i}+\frac{-2(x^2-1)y}{(y^2+1)^2}\hat{j}$$ But how do we get $\nabla f(\gamma_c(t))$ ? :unsure:For (c) :
The maximum value of the directional derivative occurs when $\nabla f$ and the unit vector point in the same direction.
But how can we find that? Dowenot need aspecific point here? :unsure:
mathmari said:
For (a) :
Hey mathmari!
Looks correct to me. (Nod)
So we have ellipses and hyperbolas.
A possible parametrization is $(a\cos t, b\cos t)$ respectively $(a\cosh t, b\cosh t)$.
Can we find the corresponding $a$ and $b$ for a specific $c$? 🤔
If we do so, we can get:
\begin{tikzpicture}
\clip (-4,-4) rectangle (4,4);
\draw[help lines] (-4,-4) grid (4,4);
\draw[-latex] (-4,0) -- (4,0);
\draw[-latex] (0,-4) -- (0,4);
\draw foreach \i in {-3,...,3} { (\i,0.1) -- (\i,-0.1) node[below] {$\i$} };
\draw foreach \i in {-3,...,3} { (0.1,\i) -- (-0.1,\i) node[ left ] {$\i$} };
\foreach \c in {-.9,-.7,...,-.1} {
\draw[domain=0:360, variable=\t] plot ({sqrt(1+\c)*cos(\t)}, {sqrt(-1-1/\c)*sin(\t)});
\foreach \c in {0.1,0.2,...,3} {
\draw[domain=-5:5, variable=\t, smooth] plot ({-sqrt(1+\c)*cosh(\t)}, {sqrt(1+1/\c)*sinh(\t)});
\draw[domain=-5:5, variable=\t, smooth] plot ({sqrt(1+\c)*cosh(\t)}, {sqrt(1+1/\c)*sinh(\t)});
\draw (-1,-4) -- (-1,4);
\draw (1,-4) -- (1,4);
\end{tikzpicture}
mathmari said:
For (b) :
First we'll need to find $\gamma_c(t)$, which we can then substitute. :unsure:
mathmari said:
For (c) :
But how can we find that? Do we not need a specific point here?
We can also tell by looking at the graph of the level curves.
The gradient is highest where the curves are closest together.
Where is that? 🤔
For the ellipse we have $$x^2-cy^2-(c+1)=0 \Rightarrow x^2-cy^2=(c+1) \Rightarrow \frac{x^2}{\sqrt{c+1}^2}+\frac{y^2}{\left (\sqrt{\frac{c+1}{-c}}\right )^2}=1$$ So does that mean that $a=\sqrt{c+1}$ and $b=\sqrt{\frac{c+1}{-c}}$ with $-1<c<0$ ?
So is a parametrization $\gamma_c=\left (\sqrt{c+1}\cos(t), \sqrt{\frac{c+1}{-c}}\sin (t)\right )$ ? For the hyperbola we have $$x^2-cy^2-(c+1)=0 \Rightarrow x^2-cy^2=(c+1) \Rightarrow \frac{x^2}{\sqrt{c+1}^2}-\frac{y^2}{\left (\sqrt{\frac{c+1}{c}}\right )^2}=1$$ So does that mean that $a=\sqrt{c+1}$ and $b=\sqrt{\frac{c+1}{c}}$ with $c>0$ ?
So is a parametrization $\gamma_c=\left (\sqrt{c+1}\cosh(t), \sqrt{\frac{c+1}{c}}\sinh (t)\right )$ ? Do we have to consider also the cases $c=0$ and $c=-1$ ? :unsure:
Yep. (Nod)
This only covers the parts of the hyperbolas with positive x. :rolleyes:
I guess so. After all, the question asks for each connected component of non-empty level curves.
So we should add them for completeness. 🤔
Do you mean to take at each $a$ and $b$ also the minus sign?
I mean: $\gamma_c=\left (\pm\sqrt{c+1}\cos(t), \pm\sqrt{\frac{c+1}{-c}}\sin (t)\right )$ and $\gamma_c=\left (\pm\sqrt{c+1}\cosh(t), \pm \sqrt{\frac{c+1}{c}}\sinh (t)\right )$ ? :unsure:
For $c=0$ we have the lines $x=\pm1$. Is a parametrization $\gamma_0(t)=(t,0)$ ? :unsure:
For $c=-1$ we have the point $(0,0)$. Is a parametrization $\gamma_{-1}(t)=(0,0)$ ? :unsure:
mathmari said:
Do you mean to take at each $a$ and $b$ also the minus sign? I mean:
No need to invert the y-coordinate.
We have both:
$$\gamma_c^+(t)=\left (\sqrt{c+1}\cosh(t), \sqrt{\frac{c+1}{c}}\sinh (t)\right )$$
and:
$$\gamma_c^-(t)=\left (-\sqrt{c+1}\cosh(t), \sqrt{\frac{c+1}{c}}\sinh (t)\right )$$
which are the two unconnected components of the same hyperbola. 🧐
Suppose we substitute $t=2$, then we get $(2,0)$.
That doesn't have $x=\pm1$. Furthermore, $y$ is not restricted to be $0$ is it? :oops:
Yep. (Nod)
We have both:
$$\gamma_c^+(t)=\left (\sqrt{c+1}\cos(t), \sqrt{\frac{c+1}{-c}}\sin (t)\right )$$
and:
$$\gamma_c^-(t)=\left (-\sqrt{c+1}\cos(t), \sqrt{\frac{c+1}{-c}}\sin (t)\right )$$
In that way we write both the hyperbola and the ellipse, or not? :unsure:
Ah yes! So is the parametrization $\gamma_0(t)=(1,t)$ ? :unsure:
My mistake. I meant to write $\cosh$ and $\sinh$. (Blush)
They were just for the hyperbola.
I've corrected that in my previous post now.
Oh, and we don't need $\pm$ for the ellipse at all. The parametrization already covers the whole ellipse, which is one connected component after all. :geek:
Yes... but that is only for $x=+1$. We are still missing $x=-1$. 🧐
Why do we need to do that only for the hyperbola? :unsure:
Oh yes! It must be $\gamma_0(t)=(\pm 1, t)$, right? :unsure:
Because a hyperbola consists of 2 disconnected parts.
The parametrization $(a\cosh t, b\sinh t)$ is only for the part with positive x.
When we put a minus ($-$) before the x-coordinate, we effectively mirror it in the y-axis so that we get the part with negative x.
But when we mirror an ellipse in the y-axis, we just get the same ellipse. (Nerd)
Yep. (Nod)
Ahh ok! At question (b): Do we substitute at $\nabla f(x,y)=\frac{2x}{y^2+1}\hat{i}+\frac{-2(x^2-1)y}{(y^2+1)^2}\hat{j}$ the parametrizations? Or do we calculate first $f(\gamma_c(t))$ and then the derivative? :unsure:
The derivative $\frac d{dt}\left (f(\gamma_c(t))\right)$ is something different isn't it? 🤔
Yes!
At the second part of the question we have to use the partial derivative and the dot product, or not ? :unsure:
Where is that? 🤔
At x=2 ans x=-2? :unsure:
Which partial derivative? 🤔
mathmari said:
At x=2 ans x=-2?
Suppose we evaluate the gradient at (x,0).
What do we get? 🤔
Will it be largest at x=2? 🤔
I meant the gradient. So do we have to calculate the dot product of $\nabla f(\gamma_c(t)) $ and $\gamma_c(t) $? :unsure:
Not $\gamma_c(t) $. We need a tangent vector of the level curve at $\gamma_c(t)$. 🤔
How do we find the tangent vector? I got stuck right now. :unsure:
Isn't $\dot\gamma_c(t)$ a tangent vector (if it is not 0)? 🤔
What do we get? 🤔
We get then $(2x,0)$, so the largest is not at $x=2$, but gets larger as $x$ gets larger. So how do we get the maximum? :unsure:
mathmari said:
We get then (2x,0), so the largest is not at x=2, but gets larger as x gets larger.
Indeed. So the largest gradient is infinitely large.
Then again... perhaps that's not what the question was asking for. (Blush)
I guess we need to find the largest directional derivative at a specific point.
Since the directional derivative is the dot product of the corresponding unit vector and the gradient, it is largest if that unit vector points in the same direction as the gradient.
In other words, the direction is the same as the direction of the gradient.
And the magnitude is the same as the magnitude of the gradient. 🤔
So the direction is \begin{equation*}\nabla f(x,y)=\frac{2x}{y^2+1}\hat{i}+\frac{-2(x^2-1)y}{(y^2+1)^2}\hat{j}=\left (\frac{2x}{y^2+1}, \ \frac{-2(x^2-1)y}{(y^2+1)^2}\right )\end{equation*} and the magnitude is \begin{equation*}\|\nabla f(x,y)\|=\sqrt{\left (\frac{2x}{y^2+1}\right )^2+\left ( \frac{-2(x^2-1)y}{(y^2+1)^2}\right )^2}\end{equation*} ? :unsure:
Yep. (Nod)
Yep. (Nod)
Great! Thank you! (Sun)
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 16 ·
