Lie Bracket * Matrix * vector (Need proof)
The discussion centers on proving the equality W*S*W*s = S*W*W*s using Lie Bracket properties in the context of skew symmetric matrices. The participants clarify that W and S represent skew symmetric matrices derived from angular velocity and position vectors, respectively, in a three-dimensional space. The conclusion drawn is that if W is invertible and the dimension is greater than two, then [W,S] does not equal zero, indicating a non-commutative relationship. The proof is supported by symbolic manipulation in MATLAB, confirming that the expression simplifies to zero.
  • Understanding of Lie Bracket and its properties in linear algebra.
  • Familiarity with skew symmetric matrices and their applications in physics.
  • Knowledge of vector operations, particularly cross products in three-dimensional space.
  • Proficiency in MATLAB for symbolic computation and matrix manipulation.
  • Study the properties of Lie Brackets in the context of Lie algebras.
  • Learn about skew symmetric matrices and their role in rigid body dynamics.
  • Explore vector calculus, focusing on cross products and their geometric interpretations.
  • Practice symbolic manipulation in MATLAB, particularly with matrix operations and simplifications.
This discussion is beneficial for mathematicians, physicists, and engineers working with rigid body dynamics, linear algebra, and those interested in advanced matrix theory and its applications in mechanics.
Trying2Learn
TL;DR
Relationship of Skew Symmetry, vectors, cross product and Lie Bracket
As an aside, fresh_42 commented and I made an error in my post that is now fixed. His comment, below, is not valid (my fault), in that THIS post is now fixed.Assume s and w are components of vectors, both in the same frame
Assume S and W are skew symmetric matrices formed from the vector components
I want to prove this (that I CAN commute the first two terms on each side)
W*S*W*s = S*W*W*s
Thus, I want to prove
W*S*W*s - S*W*W*s = 0
(W*S-S*W)*W*s =0
However, the parenthetical is the Lie Bracket. Thus
[W,S]*W*s = 0
So, is the above, true?
I can show it works for any general skew symmetric system, using the symbolic manipulator in Matlab
But can someone explain why this is true?
You need to specify the dimensions of the vectors are taken from, or the dimension of the matrices. And what is ##s## for? Did you mean ##V=S## and what does ##W,V## consists of the components of ##v,w## mean?
If the dimension is greater than two, and ##s\neq \vec{0}##, and ##W## is invertible, then ##[W,S]\neq 0## in general, i.e. for arbitrary ##S##.
Maybe you can give an example because your question is too flawed to answer.
The dimension of all is 3.
w is related to an angular velocity vector
s are the position vector
In the process, I derive this term that I KNOW must be zero (I just can't prove it):
W*S*W*s = S*W*W*s
I can REASON my way around it like this:
I want to prove
(W*S-S*W)*W*s =0
However, the parenthetical is the Lie Bracket (A Commutation relationship). Thus
[W,S]*W*s = 0
OK, so v = W*s is a vector perpendicular to w and s
The Lie Bracket is a skew matrix representing a vector perpendicular to w and s
This means that [W,S] and v are parallel
Thus, their cross product must be zero
However I do not like that proof. It seems to be a lot of handwaving and too much reliance on the cross product.
And I apologize: there was no need for v or V. I meant s and S.
I have corrected that mistake in my original post.
I still have difficulties understanding it. If ##[W,S]Ws=0## and ##W## is regular, then ##[W,S]=0## but this isn't the case for arbitrary skewsymmetric matrices of dimension three. So either ##s\in \ker W## or ##Ws \in \ker [W,S].## Hence we need to look at your additional geometric conditions. However, I don't see how to apply them.
I am sorry for confusing you: it is my fault for lack of precision (which actually derives directly from my very confusion)
So here... I wrote a Symbolic Manipulator Matlab script. This script gives me the result of ZERO.
I now wish to prove this
---------------------------------------------------Test.m-----------------------------------
% Declare symbolic varitables to be real
syms w1 w2 w3 s1 s2 s3 v1 v2 v3 real
% Create two symbolic vectors
w = [w1;w2;w3]
s = [s1;s2;s3]
% Create their associated skew symmetric form (as if to be used in the cross product)
W =[0,-w3,w2;w3,0,-w1;-w2,w1,0]
S =[0,-s3,s2;s3,0,-s1;-s2,s1,0]
%Perform the operation
T=simplify((expand(W*S*W*s-S*W*W*s)))
I get the components of a zero vector!
I get exactly what I want.
(This is from the realm of rigid body dynamics -- nothing advanced as you would find it relativity or advanced geometric space-time, etc.)
Why?
Trying2Learn said:
Thank you!
t
Maybe you can shorten the calculationn by splitting ##W=W_0+W_1\, , \,S=S_0+S_1## into upper and lower triangular matrices and use the facts that they are multiplicative closed and ##W_1=-W_0^\tau\, , \,S_1=-S_0^\tau .##
Actually, I found a better way.
Remember, in my problem, s and w were the vectors
S and W were the corresponding skew symmetric forms.
We already know that Ws and Sw are manifestations of the cross product.
Thus:
Ws is perpendicular to w and s
Sw is perpendicular to w and s.
Next, I investigate:
[W,S] = WS - SW
I use an alternating tensor to represent a skew symmetric form.
I find any skew symmetric form has elements such that:
Wij = -eijk wk
Sij = -eijk sk
Then I go through the process of forming
[W,S]ij = (WS - SW)ij
I find that that last form is ALSO perpendicular to w and s.
Thus,
[W,S] * Ws represents a cross product of two parallel vectors
[W,S] * Sw represents a cross product of two parallel vectors[W,S]Ws = 0
[W,S]Sw = 0
And I am done
  • · Replies 16 ·
  • · Replies 20 ·
