Why Is the Lie Bracket a Vector Field on a Manifold?
The discussion centers on the mathematical proof that the Lie bracket of two vector fields, denoted as ##[X, Y]##, is indeed a vector field on a manifold, while the products ##XY## and ##YX## are not. The participants clarify that the Lie bracket can be expressed as ##[X,Y]f = X[Y[f]] - Y[X[f]]##, which involves first-order derivatives, while the products yield second-order derivatives, thus failing to meet the criteria for vector fields. The cancellation of second-order derivatives between the products is highlighted as a key point in understanding this distinction.
  • Understanding of vector fields on manifolds
  • Familiarity with the concept of Lie brackets
  • Knowledge of first-order and second-order derivatives
  • Proficiency in applying the Leibniz rule in calculus
  • Study the properties of Lie brackets in differential geometry
  • Explore the implications of the Leibniz rule in vector calculus
  • Investigate the relationship between vector fields and tensors
  • Learn about the applications of vector fields in physics and engineering
Mathematicians, physicists, and students of differential geometry who are interested in the properties of vector fields and their applications in various fields of study.
Silviu
Hello! So I have 2 vector fields on a manifold ##X=X^\mu\frac{\partial}{\partial x^\mu}## and ##Y=Y^\mu\frac{\partial}{\partial x^\mu}## and this statement: "Neither XY nor YX is a vector field since they are second-order derivatives, however ##[X, Y]## is a vector field". Intuitively makes sense but I am not sure how to show it mathematically. I tried this: for a function f defined on M, ##[X,Y]f = X[Y[f]]-Y[X[f]]=X^\mu\frac{\partial}{\partial x^\mu}[Y^\nu \frac{\partial}{\partial x^\nu}f]-Y^\mu \frac{\partial}{\partial x^\mu}[X^\nu \frac{\partial}{\partial x^\nu}f]##. It kinda makes sense that you first apply the vector on the right to f, which gives you a number, and the vector on the right remains just as an operator, and hence the whole stuff is a vector (but I am not sure if the results on the right can be put before the derivative on the left, such that we have an actual vector). For the other case ##XY[f]## I am not really sure how to combine the indices and what to get outside the derivatives. I guess I should have something like ##X^\mu Y^\nu \frac{\partial}{\partial x^\mu x^\nu}##, I think, which is not a vector (would it be a tensor?), but I am not sure. Can someone help me a bit here? Thank you!
The case of XY is just part of the Lie bracket that you have. ##X[Y[f]]## is computed in exactly the same way, but will contain second order derivatives. The point is that the second order derivatives cancel between XY and YX.
I don't understand "can be put before the derivative on the left" but what you've written is correct.
To see why ##[X,Y]## is a vector field while ##XY## is not, you should compute ##[X,Y](f\cdot g)## and check for the derivative property in comparison to ##(XY)(f\cdot g)##. Coordinates are not needed here, which makes the computation a bit easier.
But if what I wrote there is correct, where exactly will the second order derivative cancel, and where the first order one remain? I am not sure how to continue what I did.
You have to use the Leibniz rule.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 16 ·
