Light (frequency, wavelength etc.)
The discussion focuses on estimating the distance at which the tail-lights of a vehicle appear as a single orange/red blob when viewed from a dark-adapted eye. Key parameters include the wavelength of red light at 700 nm, the diameter of a dilated pupil at approximately 2 cm, and the use of single-slit diffraction to determine the angular size of the Airy disk. The small-angle approximation is essential for relating the apex angle of the triangle formed by the tail-lights to the distance from the observer's eye.
  • Understanding of light wavelength and color (700 nm for red light)
  • Knowledge of human eye anatomy, specifically pupil size (2 cm)
  • Familiarity with single-slit diffraction and Airy disk concepts
  • Ability to apply the small-angle approximation in geometric contexts
  • Study the principles of single-slit diffraction and how it relates to light resolution
  • Learn about the small-angle approximation and its applications in optics
  • Explore the characteristics of the Airy disk and its significance in visual perception
  • Investigate the relationship between light wavelength and color perception in human vision
Students in physics or optics courses, educators teaching light and vision concepts, and anyone interested in the practical applications of diffraction in everyday scenarios.
tim_3491
Imagine that you are in a vehicle at night on a long straight road. There are no streetlights and one vehicle up ahead in the distance.
Estimate how far away the other vehicle would be for its tail-lights to appear as a single
orange/red blob.
In your answer, make quantitative estimates to characterise:
• the colour of the light emanating from the tail-lights
• the spatial separation of the tail-lights
• the size of the pupil of your dark-adapted eye.
red light has lambda = 700nm (700*10^-9m) but now i am not sure what to do. I need to equate/use lambda, lense of an eye and focal length/distance to car.
Have you had the material yet on single-slit diffraction? In this case, you will want to know the angular size of the "central maximum" for diffraction through a circular aperture (the size of the so-called Airy disk). The diameter of the dilated human pupil is about 2 cm. Draw a picture of the triangle formed by the two taillights and the location of your eye. You will want to use the "small-angle approximation" to find the relationship between the apex angle of that triangle, the separation of the lights, and the distance to your eye. The apex angle will equal the angular size of that central maximum when the taillights are at the "limit of resolution", which is the minimum distance at which you will see the two taillights as one light source.
  • · Replies 22 ·
61K
