LightCone Calculator Improvements
  • Context: Undergrad
  • Thread starter Thread starter Jorrie
    Calculator
100 replies · 9K views
This is as expected. See my post #26. Either Ωm,0 or ΩLambda,0 has to give if we want to keep OmegaT,0=1.
Astronomy news on Phys.org
pbuk said:
Note that with the current settings @Jorrie's development fork is served at https://burtjordaan.github.io/light-cone-calc.github.io/docs/.
Thanks for providing the runable link, because I still have finger trouble with Github. Note that this is not the latest version, which JimJCW (somehow) got hold of, albeit with the actual OutputCSV.js missing - Github seems to be a difficult animal to understand at my age...
I think if at input Ωm,0 = 0.3111 but at output it becomes Ωm,0 = 0.3110082030, it is a discrepancy.
ICRAR, in this situation, gives,
The space will not be flat in this case.
You are right, but to output OmegaT,0 >1 would also be a discrepancy, because without giving the value explicitly, the collaboration the spatial flatness in words, if I read the paper correctly.
So maybe we miss something in the equations, but as a non-cosmologist, I can't figure out what.
Our previous versions of Lightcone8 suffered the same problem.
I'm also still perplexed as to why the Trial Version does not have CSV output option working when selected. I did upload it with the OuputCSV.js file (a new file that was not there is earlier versions) and it shows on my fork.
Ok, found error for CSV output and fixed it.
Should now work on http://jorrie.epizy.com/docs/index.html
Yes I agree, if we want curvature then I think this must be input explicitly as it is in LightCone7 and 8. I'm not a cosmologist either, but I don't think we are missing anything, we just have to deal as modellers with the fact that our inputs are uncertain. The objective in creating any physical model is not to faithfully reproduce inputs, it is to create an output that is the best fit to the observations. With this in mind I plan to do some investigation on how best to 'spread' the Ωrad,0 adjustment to achieve the best fit to t0 (age).
But I think the alternative which is to have an input of Ω0 = 1 become an output of Ω0 = 0.9999101295 is worse: non-zero curvature is "a big thing" and is something that should be explicitly input, not extracted out of what is more or less rounding errors.
I think this may have got lost when I imported from your fork - because I can't create pull requests from your fork I had to clone it and copy files over: I picked up the changed files but must have missed the addition.
Let’s use PLANCK(2018+BAO) as an example for the following discussion (see Post #25):
If we insist to have,
we are forced to have,
So, Ω0 cannot be 1 in this case.
If we set ‘Total density parameter, Ω’ in LightCone8.1.2 - Jorrie to be 1.000091824, the discrepancy is eliminated:
To summarize:
We cannot insist that ΩΛ,0 + Ωm,0 =1 as is done in Planck 2018 results. I and still have Ω0 = 1.​
@pbuk
This is not correct. Planck 2018+BAO gives us ## \Omega_{m,0} = 0.3111 \pm 0.0056; \Omega_{\Lambda,0} = 0.6889 \pm 0.0056 ##. Now we can argue about the independence of those errors, but they certainly don't give us ## \Omega_{m,0} + \Omega_{\Lambda,0} = 1.00000 000 \pm 0.00000 000 ##. Adjusting ## \Omega_{m,0} ## to 0.311008176 to accommodate ## \Omega_{rad,0} ## is still within ## 0.02 \sigma ## of the survey result!
Let's look at the values at ## t = t_0 ##as they are now with Planck 2018+BAO selected, and with ## \Omega_{m,0} ## forced to 0.3111
ParameterPlanck 2018+BAOLightCone8 defaultForced ## \Omega_{m,0} ##
## \Omega_{\Lambda,0} ##0.6889±0.00560.68890000000.6889000000
## \Omega_{m,0} ##0.3111±0.00560.31100820300.3111000000
## \Omega_{rad,0} ##~9.180e-50.000091796990260.00009182408501
## \Omega_{0} ##"Consistent with 1"1.0000000001.000091824
## \Omega_{\kappa,0} ##"Consistent with 0"0.0000000000.00009182408501
Age13.787±0.020 Gyr13.78704250 Gyr13.78629120 Gyr
Now OK, it doesn't make a huge amount of difference (except to curvature itself of course), but LightCone8 as it is gets the age of the Universe bang in the middle of the Planck 2018+BAO result whereas if you allow positive curvature it is 1 out in the 5th significant figure. This is not the point though, the Planck 2018 results are fitted with the assumption of flatness so it is inconsistent to use the numbers to say there is curvature.
I think LightCone8 is working properly. We can use it to verify the following table:
It suggests we cannot insist that ΩΛ,0 + Ωm,0 =1 and still have Ω0 = 1 and Ωk = 0.
We may be able to use statistical argument to say that Ω0 is approximately equal to 1 for a particular observation data, but it is not.
So what is the consensus: do we declare Lightcone8 with the trail UI interface as good enough, meaning we take away the "Jorrie Trial UI" in the title, or do we wait for a cosmologist to advise us?
My opinion is that as an educational tool, it is as good as it needs to be.
I am confused. Currently I am looking at two versions:
LightCone8: https://burtjordaan.github.io/light-cone-calc.github.io/
LightCone8.1.2 - Jorrie Trial UI: https://light-cone-calc.github.io/
Which one are we talking about? Do you mean replacing LightCone8 with LightCone8.1.2 - Jorrie Trial UI?
@pbuk
Yes, that the trail becomes the "official model", provided that we agree that we should input these 5 parameters, all givens by the Planck collaboration.
Our model implementation then forces ##\Omega## to be whatever this input is (default 1, but we are allowed to change this for educational purposes).(a) This is done by subtracting ##\Omega_R## from ##\Omega_M##.
Or we can decide to go more sophisticated by using a statistical method, based on the given error bars on all the inputs. My suggestion is that the "trail version" is good enough for now.
Footnote (a). When we started the original project, the then-core members were keen to keep options open so that hypothetical open and closed models could be demonstrated. Plus of course to be ready for potential future observation favoring a universe that is not spatially flat.
I am still concerned with the discrepancy that at input, Ωm,0 = Matter density parameter, ΩM = 0.3111, but at output, Ωm,0 = OmegaM = 0.311008203. Some people may consider it as an error in the calculator.
What will happen to ‘LightCone8: https://burtjordaan.github.io/light-cone-calc.github.io/’? Will it be still available?
I think one should not take numbers in Planck 2018 results. I inflexibly. Using Planck + BAO as an example, it gives,
They do not add up to Ω0 = ΩΛ,0 + Ωm,0 + ΩR,0 =1 and are, therefore, not consistent with LightCone 8 Tutorial Part III – How Things are Computed,
The Ω without subscript represents the present overall density parameter: Ω=ΩΛmr, which adds up to unity in the case of flat space.​
@pbuk
I don't think so, because it gives exactly the same "error", if we can call it that. It likewise reduces Ωm,0 to 0.3110 in order to keep Ω0 =1. So no benefit in keeping it, AFAICS.
I tend to agree with @pbuk that it is preferable to "err" in ##\Omega_{m,0}##, rather than allowing Lightcone8 to output a non-unity Ω0. Maybe we should reduce both ##\Omega_{m,0}## and ##\Omega_{\Lambda,0}## proportionally.
We can easily explain the discrepancies in the UI.
Do you think we should use the Planck + BAO as initial default? I used the second last column, because the collaboration calls it their "base data".
I believe LightCone8 (https://burtjordaan.github.io/light-cone-calc.github.io/) is functioning properly. Its results are consistent with those of ICRAR (see Post #22) and its calculated Ω’s can be verified with equations in LightCone 8 Tutorial Part III – How Things are Computed (see Post #148 of the thread A glitch in Jorrie’s Cosmo-Calculator?). I think at least this version should be kept as an option.
I think the discrepancy in LightCone8.1.2 - Jorrie Trial UI (https://light-cone-calc.github.io/) (see Post #46) is caused by a mathematical error. The calculator is requiring the following two equations to be valid at the same time in a flat space, but this is impossible:
ΩΛ,0 + Ωm,0 = 1​
ΩΛ,0 + Ωm,0 + ΩR,0 = 1​
The origin of the above problem can be traced to Planck 2018 results. I. We shouldn’t use the numbers in it inflexibly. Using Planck + BAO as an example, it gives,
@pbuk
Jim, I don't quite understand your objection against https://light-cone-calc.github.io/, because the two give identical outputs for the Planck + BAO input data, i.e.
against https://light-cone-calc.github.io/ :
Both deviate from the Planck + BAO input data for Ωm, for reasons discussed before.
IMO, it is simply a matter of Lightcone not taking the error bars into account. To include those would be an unnecessary complication for a relatively simple educational tool. I will update the UI and the Tutorial to explain the rationale and then remove the "Trial version" in the title.
Besides that, the newer version has the additional functionality of a full precision CSV output option.
If you want to preserve the previous version visibly on the Forum, simply put that link in your Forum signature, but mark it as "alternative UI" or something to that effect.
Ok, I have made the changes discussed above in the UI. Must still update Tutorial to explain.
An important change to take note of, is that I have reduced the mapping value of ##\Omega_{\Lambda,0}## input by 0.0001 in order to accommodate radiation density into flat space and remove any ambiguity in the UI or output data. So for now there is nothing extra to be done in the expansion calculation module.
The Planck collaboration says above Table 2: "The top group of six rows are the base parameters, which are sampled in the MCMC analysis with flat priors. The middle group lists derived parameters." ##\Omega_{\Lambda,0}## does not appear in the top group, but baryons and dark matter do. Hence I took it that ##\Omega_{m,0}## takes priority and so I changed ##\Omega_{\Lambda,0}## by the mentioned small amount.
@pbuk and @JimJCW. Comments?
Jorrie said:
Jim, I don't quite understand your objection against https://light-cone-calc.github.io/, because the two give identical outputs for the Planck + BAO input data, . . .
Among Ω0, ΩΛ,0, Ωm,0, ΩR,0 and zeq, only three of them can be used as inputs because of the following two relations:
LightCone8 (https://burtjordaan.github.io/light-cone-calc.github.io/) correctly uses only three: Ω0, ΩΛ,0, and zeq, but LightCone8.1.2 - Jorrie Trial UI (https://light-cone-calc.github.io/) incorrectly uses four: Ω0, ΩΛ,0, Ωm,0, and zeq. This causes the discrepancy in LightCone8.1.2 (see Post #30, #40, and #42).
I noticed that in LightCone8.1.2 the inputted Ωm,0 is used only in calculating ΩR,0 printed to the right. The rest of the calculations is the same as LightCone8, using only Ω0, ΩΛ,0, and zeq. Let me illustrate this using an exaggerated example (setting Ωm,0 = 0.9):
The output remains the same as in LightCone8:
So, using both ΩΛ,0 and Ωm,0 as inputs at the same time is incorrect and produces discrepancies.
Suggestion:
We can use Ωm,0 and ΩR,0 as derived quantities and print them on the right-hand side:
JimJCW said:
Suggestion:
Oops, yes thanks for the headsup - I see now that the table calculation module ignores the matter density input value. I will temporarily reset the old input tables. But I would still like to use Ωm,0 as one of the primary inputs (for reasons that I mentioned in my prior post). So it would mean swapping ΩL and Ωm in what you have above.
To do the change in primary input, @pbuk must also alter his calculation module to use Ωm,0 as primary input. I will coordinate with him to get us there.
Please see Post #13:
If Ωm,0 is used as input (see Post #2, where seq = zeq + 1),
ΩΛ,0 = Ω0 - Ωm,0 (zeq + 2) / (zeq + 1)
ΩR,0 = Ωm,0 / (zeq + 1)
@pbuk
The underlying model (since 24 July) does use Ωm,0, but only if ΩΛ,0 is not provided by the UI coupling. In that case it will apply the whole of the Ωrad,0 adjustment to ΩΛ,0, which I think we have agreed is not the best thing to do. If ΩΛ,0 is provided it will apply the whole of the Ωrad,0 adjustment to Ωm,0.
JavaScript:
    // Use omegaLambda0 if it is provided.
    if (props.omegaLambda0 != null) {
      omegaLambda0 = props.omegaLambda0;
      omegaM0 = (omega0 - omegaLambda0) * (sEq / (sEq + 1));
    } else if (props.omegaM0 != null) {
      omegaM0 = props.omegaM0;
      omegaLambda0 = omega0 - omegaM0 * ((sEq + 1) / sEq);
    } else {
      throw new Error('Must provide either omegaM0 or omegaLambda0');
(see https://github.com/cosmic-expansion...0b12217c50ce8991181686fd406/src/model.ts#L156)
I think what we are now suggesting is that if both Ωm,0 and ΩΛ,0 are provided we should apply the Ωrad,0 adjustment proportionately across Ωm,0 and ΩΛ,0?
I'll have a look at this.
Yes, although I started to think we must use Ωm,0 (as the more directly established parameter), I guess that since we do not yet understand why the Planck collaboration have elected to present the data with this apparent inconsistency, it may be best to take their exact values at face value as inputs.
Since we are desirous to keep Ω0 = 1, I suppose we can decide how to process that. Adjusting proportionately across both seems to be the more neutral scheme.
The source of our problem is that Planck 2018 results. I data is incorrect for a flat universe:
We shouldn’t use these numbers as given at the same time.
We have been using ΩΛ,0 as input and Ωm,0 and ΩR,0 as derivatives. We are planning to use Ωm,0 as input and ΩΛ,0 and ΩR,0 as derivatives. I think either one is good.
@pbuk
If we ever find Omega_0 slightly above 1, the most likely culprit will be dark matter. Here is a graph for Omega_0 = 1.1 (an exaggerated case for visibility)
Interesting how Omega will first rise (in this case overshooting the the "current 1.1" slightly) and then being dragged down to unity again by dark energy dominance.
The expansion of space in the Big Bang model makes many situations very complicated. I often use the LightCone calculator to help me to get pictures in my mind. The following two pictures are similar to yours:
For Ω0 = 1:
For Ω0 = 0.9:
