Limit at infinity that may or may not be e
The limit as x approaches infinity of (1 + 1/x^2)^x is being evaluated. Initially, there was confusion about whether this limit would yield e, similar to the limit of (1 + 1/x)^x. However, through analysis using L'Hôpital's Rule, it was determined that the limit actually approaches 1. The discussion highlighted that 1 raised to an infinite power is an indeterminate form, which can lead to different results depending on the context. Ultimately, the correct conclusion is that the limit is indeed 1.
Marylander
Compute lim as x goes to infinity of (1+1/x^2)^x
I know that lim at infinity (1+1/x)^x=e
I do not know if that is still valid with the x^2 there. I don't really think it is, but it's throwing me off.
Beyond the above bit of knowledge, 1/x^2 goes to 0, leaving me with 1 to a power. So the limit should be 1, I believe, but I want to make absolutely sure.
[1^{\infty}] is one of several indeterminate forms. The way to evaluate lim (1 + 1/x)^x is by letting y = (1 + 1/x)^x, and then taking the natural log of both sides and getting to something that you can use L'Hopital's Rule on. Do the same thing with your limit.
1^infinity is indeterminate? How? 1 is always 1, isn't it?
EDIT: And sorry, the limit I'm trying to do isn't (1+1/x)^x, it's (1+1/x^2)^x. Is it the same process?
EDIT2: Okay... so lim (1+1/x^2)^x is also e? Or at least that's what I got, anyway.
Yes.
Marylander said:
How?
If you mean Why? the reason is that a limit expression in which the base is approaching 1 but the exponent is becoming infinitely large can turn out to be anything.
Well 1 is always 1, that's true, and 1n = 1 provided that n is a finite number.
Yes.
Very impressive monosyllables there. :smile:
And thanks for the help. I see how to deal with this. Which is good, because it's just about inevitable that I'll have to for my final.
If this board let me rep you or something I would, but you're just have to make do with the much-sought-after textual thanks.
Be careful. The process for finding lim (1+1/x^2)^x is the same as (1+1/x)^x, but the answer isn't the same. It's not 'e'. Can you show how you got that?
Great...
Sure:
elim(x(ln(1+1/x2))
lim xln(1+1/x2)=lim ln(1+1/x2)/(1/x)
L'Hopital:
Lim 1/(1+1/x2)*(-x-2)/-x-2
Lim 1/(1+1/2)=1
e1
EDIT: Ah. There's where I messed up. It should be...
Edit2: elim 2/(x(1+1/x2)
That limit is 0, so it's e0=1, which was my original answer.
Marylander said:
Great...
Sure:
elim(x(ln(1+1/x2))
L'Hopital:
Lim 1/(1+1/2)=1
e1
That's the right idea, but the derivative of 1/x^2 is -2/x^3. Not -x^(-2).
Yeah, I caught that after I submitted it. Absent-minded simple messups.
The edits have my corrected answer. The limit is 1, correct?
Correct.
Thanks again for all the help.
  • · Replies 23 ·
