Limit does not exist but function exist
  • Thread starter Thread starter funlord
    Function Limit
6 replies · 5K views · last reply
funlord
there are four cases on limits given to us, and one of them I didnt really understand.
This case was: Limit f(x) as x approaches a does not exist but f(a) exist.
My answer here that the limit in this piecewise defined function exist,
As x approaches -5 from the left, it uses the function x+3;
And as x approaches -5 from the right, it uses the function √(25-x^2)please give me a great explanation with this case
Thank you
Thank you
Do you really think that 0 = -2? That would need to be true in order that f(x) have a limit as x → -5.
This suggests that the limit should be -2.
This suggests that the limit should be 0.
A limit of f at 5 is a number L such that for all ##\varepsilon>0## there's a ##\delta>0## such that the following implication holds for all real numbers ##x##.
$$0<|x-5|<\delta\ \Rightarrow\ |f(x)-L|<\varepsilon.$$ The implication is saying that f maps the interval ##(5-\delta,5+\delta)## into the interval ##(L+\varepsilon,L-\varepsilon)##.
Now let's see if there a ##\delta>0## with the property above, in the special case when ##\varepsilon=1##. No matter how small we choose ##\delta##, there's an x in the interval ##(5-\delta,5+\delta)## such that f(x) is not in the interval (-2-1,-2+1)=(-3,-1). (Choose x slightly greater than 5, so that f(x) is very close to 0). This implies that -2 can't be a limit. And there's also a y in the interval ##(5-\delta,5+\delta)## such that f(y) is not in the interval (0-1,0+1)=(-1,1). (Choose y slightly less than 5, so that f(y) is very slose to -2). This implies that 0 can't be a limit.
Yes, and so as x gets closer and closer to -5 (from the left), f(x) gets closer and closer to -5+ 3= -2.
Yes, and so as x gets closer and closer to -5 (from the right), f(x) gets closer and closer to √(25-(-5)^2)= 0.
But we can't say that f(x) gets closer and closer to anyone number as x gets closer and closer to -5.
Thank you
There is a typo on that page the image is taken from:
It seems this should have said:
##\displaystyle\ \lim_{x\to -5}\, f(x) \ \text{ does not exist. [why?]} \ ##​
As it's stated in your image, the limit does exist. It's simply the same as the constant ƒ(-5) , which is zero .
Does the problem say "there exists an a such that..." or "for all a.."
Also, are you required to give an equation as the representation of a function? A function can be represented in 4 different ways: in words, as an equation, in a table, and as a graph. Perhaps reasoning with one of these other representations may be helpful.
