Limit of a rational function for different values of K (check)
The discussion revolves around finding the limit of the rational function (4kx + 9)/(45x + 3) as x approaches infinity for different values of K (specifically K=5, K<5, and K>5). Participants explore methods for calculating these limits and the implications of varying K on the results.
  • One participant proposes that the limits are 0 for K<5, 1 for K=5, and infinity for K>5, based on dividing each term by the highest power of 4.
  • Another participant suggests a more rigorous approach for K=5 and K>5 using a transformation involving 4^{kx} and 4^{5x} to analyze the limit.
  • A participant notes that for K<0, the terms with x in their exponent will tend to zero as x approaches infinity, leading to a limit of 0.
  • There is a discussion about the notation and formatting of mathematical expressions, with a reference to using LaTeX for clearer presentation.
  • One participant acknowledges a previous generalization in their response and expresses gratitude for the clarification provided by others.
Participants express varying methods and interpretations regarding the limits based on the value of K. There is no consensus on a single method or conclusion, as different approaches are discussed and refined.
Some assumptions regarding the behavior of terms as x approaches infinity are discussed, but not all participants agree on the implications or methods used, indicating a lack of resolution on the best approach.
MurdocJensen
Find the limit of (4kx + 9)/(45x + 3) as x->inf, when K=5, K<5, K>5.
Answer: I divided each term by the highest power of 4, and was able to come up with 0 (K<5), 1 (K=5), inf (K>5). I'm pretty sure these are correct.
Was this the right method? Am I good to assume that dividing by the highest power of x is similar in some ways to dividing by the highest power of some common base, which is what I did here?
Let me know if I can explain myself better.
You are indeed correct. If you want to be more rigorous for K = 5, K > 5, and 0 <= k < 5 use the following trick:
\frac{4^{kx} + 9}{4^{5x} + 3} = \frac{4^{kx} + 9}{4^{5x} + 3} \ * \frac{\frac{1}{4^{kx}}}{\frac{1}{4^{kx}}} = \frac{1 + 9*4^{-kx}}{4^{(5-k)x} + 3*4^{-kx}}
For k < 0, you can use what you originally typed (do you know why?)
Thanks.
And for K < 0, I can use what I originally typed because the terms with x in their exponent will tend to zero as x -> inf.
And how do you type those operations out? They look so pretty.
MurdocJensen said:
Thanks.
Yes, for K<0, we have that 4^{Kx}\rightarrow 0. And thus
\frac{4^{Kx}+9}{4^{5x}+3}\rightarrow 0
as the denominator will tend to infinity.
Click on the equations to see the code! :smile:
micromass: I was pretty general (and wrong) with my reply. Thanks for the clarification.
  • · Replies 31 ·
  • · Replies 17 ·
