Integration with different infinitesimal intervals
31 replies · 7K views · last reply
fresh_42 said:
It is questionable to use the integration variable ##t## indicated by ##dt## under the integral anywhere else.
The integral reads ##\int_a^b f(t)\,dt =\int_{t=a}^{t=b} f(t)\,dt.## This resulted in the equation ##t=x+\Delta t## for the upper bound as used in your linked article. It is disturbing to have the same variable ##t## in one equation but with two meanings! ##t=x+\Delta x## would have been the better choice.
It is further problematic to substitute ##\Delta x## by ##\delta x## or ##dx.## They have different meanings, even in case we consider ##\Delta x \to 0.## The understanding of ##dx## in their various contexts is difficult enough even without adding another context.
Thank you.
How about the upper limit of the equation in pbuk's post of this thread if we substitute ##\delta x## by ##\Delta x## giving:
$$\lim_{\Delta x \to 0} \int_a^{a+\Delta x} f(x) dx \approx \lim_{\Delta x \to 0} f(a) \Delta x$$
I'd expect you won't agree with this upper limit, even if ##a## is considered a value and not a variable? After all, ##x=a+\Delta x## would also show different meanings for ##x##.
JohnnyGui said:
Thank you.
It breaches my first rule: never use the integration variable elsewhere. I would write it as
$$\lim_{\Delta a \to 0} \int_a^{a+\Delta a} f(x) dx \approx \lim_{\Delta a \to 0} f(a) \Delta a$$
Why use ##x## if we already have ##a## for values on the ##x##-axis? If you don't like the same ##a## in ##a+\Delta a## then ##\Delta a = h## is your letter of choice.
However, this rule is for clarity. As mentioned earlier ##\int_d^{d+\Delta d}f(d)dd## is possible to write. We use the same letter for quite a couple of different meanings and its position provides context and meaning. You would certainly agree that such a formula is a nightmare rather than an integral. You could do it, but I strongly recommend not. Same with the ##x## in its double role as an integration (dummy) variable and as an upper limit. You can do it, but it causes threads like this one with meanwhile 30+ posts.
More important is the idea behind the formula. Assume that ##F## is an anti-derivative of ##f,## i.e. ##F'=f.## Let further be ##F(x)=F(a)+F'(a)(x-a)+ O((x-a)^2)## the Taylor series of ##F.## Then
\begin{align*}
\lim_{\Delta a \to 0} \int_a^{a+\Delta a} f(x) dx&=\lim_{\Delta a \to 0}( F(a+\Delta a)-F(a))\\
&=\lim_{\Delta a \to 0}(F(a)+F'(a)\cdot(a+\Delta a -a)+ O((a+\Delta a -a)^2) - F(a))\\
&=\lim_{\Delta a \to 0}(f(a)\cdot \Delta a +O((\Delta a)^2))\\
&\approx\lim_{\Delta a \to 0}f(a)\cdot \Delta a
\end{align*}
Imagine if I had used ##\Delta x## instead of ##\Delta a.## How would you know the difference to the ##x## I used as a variable in the Taylor series? It would open up another discussion about naming objects in mathematics. I like the motto: different meaning requires different letter.
