Why Are Assumptions Critical in the Limit of Composite Functions?
The discussion centers on the necessity of assumptions in the theorem regarding the limit of composite functions. Participants clarify that the assumptions ensure the existence of the limit of f(g(x)) under specific conditions, particularly when g is not defined at x. They differentiate between the technical and colloquial meanings of "necessary," noting that assumptions are required for the proof method outlined in the textbook. An example is provided to illustrate that the limit of f(g(x)) can exist even if the limit of f does not. The conversation emphasizes the importance of these assumptions in establishing the theorem's validity.
sonofagun
I need help with the following theorem:
Let I, J ⊆ℝ be open intervals, let x∈I, let g: I\{x}→ℝ and f: J→ℝ be functions with g[I\{x}]⊆J and Limz→xg(x)=L∈J. Assume that limy→L f(y) exists and that g[I\{x}]⊆J\{g(x)},or, in case g(x)∈g[I\{x}] that limy→L f(y)=f(L). Then f(g(x)) converges at x, and limz→x f(g(x))=limy→Lf(y).
I don't get why the assumptions are necessary. We're assuming that the limit of f exists when g is not defined at x, or, if g is defined at x, that the limy→L f (y)=f(L).
What assumptions would you propose to use instead?
Do you mean "necessary" in the mathematical sense (as in "necessary and sufficient") or are you asking why certain assumptions are needed to write the proof the textbook expects?
I guess what I'm struggling to understand is why the existence of the limit of f(g(x)) depends on these assumptions. For example, if limy→L f(y) did not exist or if g[I\{x}] was not contained in J\{g(x)} would that imply that the limit of f(g(x)) doesn't exist? If so, why?
No, it wouldn't.
For example, define f(x) by f(x) = 0 if x < 0 and f(x) = 1 if x \ge 0.
Lim_{y \rightarrow 0} f(y) does not exist.
Define g(x) = |x|
lim_{y \rightarrow 0} f(g(y)) = 1
You haven't explained what you mean by "necessary".
There is a technical meaning for "necessary". The theorem that "A implies B" asserts that statement(s) A are "sufficient" for statement B to be true. To say that statement(s) A are "necessary" for B to be true asserts that "B implies A" .
There is a colloquial meaning for "necessary". By that meaning, we only assert that, having a certain method of proof in mind, the statements A are required to do that particular method of proof.
I don't know whether the "if..." part of the theorem you stated is "necessary" is the technical sense. The fact that theorem is stated in a text doesn't imply that the converse of the theorem is true.
( In the theorem, lim_{z \rightarrow x} g(x) = L \in J should say "g(z)" instead of g(x) .)
Likes sonofagun
Stephen Tashi said:
No, it wouldn't.
Define g(x) = |x|
I was using the colloquial meaning of necessary.
