Limit problem using l'hopital's rule
The limit problem discussed involves calculating the limit as x approaches 2 for the expression \(\lim_{x\rightarrow2}\frac{x\sqrt{x-1}-2}{x-2}\). While L'Hôpital's Rule can be applied, a more efficient method is to rationalize the numerator and factor the expression, leading to the simplified limit of 2. The discussion highlights the use of derivatives, specifically the product rule, to derive the necessary components for evaluating the limit accurately.
  • Understanding of limits in calculus
  • Familiarity with L'Hôpital's Rule
  • Knowledge of derivative rules, particularly the product rule
  • Ability to manipulate algebraic expressions and rationalize numerators
  • Study the application of L'Hôpital's Rule in various limit problems
  • Learn techniques for rationalizing expressions in calculus
  • Explore the product rule for derivatives in more complex functions
  • Practice solving limits involving square roots and rational functions
Students studying calculus, particularly those focusing on limits and derivatives, as well as educators looking for effective methods to teach these concepts.
mtayab1994
calculate the limit
When I apply l'hopital's i have to do derivative of the top over derivative of the bottom right?
calculate the limit
Yes .
You could use L'Hopital but I would consider that "overkill". Instead, rationalize the numerator and factor:
\frac{x\sqrt{x- 1}- 2}{x- 2}\frac{x\sqrt{x- 1}+ 2}{x\sqrt{x- 1}+ 2}= \frac{x^2(x- 1)- 4}{(x- 2)(x\sqrt{x- 1}+ 2)}= \frac{x^3- x^2- 4}{(x- 1)(x\sqrt{x- 1}+ 2)}
\frac{(x- 2)(x^2+ x+ 2)}{(x- 2)(x\sqrt{x- 1}- 2)}= \frac{x^2+ x+ 2}{x\sqrt{x- 1}+ 2}
Now, let x= 2.
(We knew it would factor that way precisely because x= 2 made both numerator and denominator equal to 0.)
Another alternative:
Let \ x \ =\ y^2 + 1.
As \ \ x\to 2, \ \ y \to 1.
\lim_{y \to 1} \dfrac{(y^2 + 1)\sqrt{y^2} - 2}{(y^2 + 1) - 2} \ =
\lim_{y \to 1}\dfrac{|y|(y^2 + 1) - 2}{y^2 - 1} \ = \
\lim_{y \to 1}\dfrac{y(y^2 + 1) - 2}{y^2 - 1} \ ** \ = \
\lim_{y \to 1}\dfrac{y^3 + y - 2}{y^2 - 1} \ = \
\lim_{y \to 1}\dfrac{(y - 1)(y^2 + y + 2)}{(y - 1)(y + 1)} \ = \
\lim_{y \to 1}\dfrac{y^2 + y + 2}{y + 1}
Continue . . .
** \ Note: \ \ \ As \ \ y \ \ is \ \ positive \ \ near \ \ 1, \ \ |y| = y.
I used L'Hopital's rule, and I think it's actually simpler in this case. The derivative of the denominator is 1, the derivative of the constant 2 is 0 so ...
The derivative of the denominator is 1, \ \ \ \ Yes, \ \ so \ \ evidently \ \ you're \ \ done \ \ discussing \ \ the \ \ denominator.
the derivative of the constant 2 is 0 \ \ \ \ No, \ \ if \ \ you \ \ are \ \ now \ \ discussing \ \ the \ \ numerator,you \ \ are \ \ to \ \ be \ \ taking \ \ the \ \ derivative \ \ of \ \ \ x\sqrt{x - 1} - 2.
And \ \ that \ \ derivative\ \ is \ \ not \ \ equal \ \ to \ \ zero.
so ...
I meant that the derivative of the constant -2 (which appears in the numerator) is 0, so we just have to use the product rule to take the derivative of x*sqrt(x-1). The result,
√(x-1) + (x/2)*((√(x-1))^(-1))
... sorry I don't have practice entering these equations on this system ... but now you can just sub in x = 2 and the limit falls right out.
√(2-1)+(2/2)*((√(2-1)^(-1))
√1 + (1)*(1/√1)= 2
what could be simpler?
I hope I put in the right number of parens.
Yes I solved it guys thanks for the help. By the way the problem stated on solving it using l'hopital's rule
  • · Replies 34 ·
  • · Replies 21 ·
