Limits of a Function: Q45 - Can't Figure It Out
7 replies · 2K views · last reply
athrun200
See the first photo.Q45
Can I use the method similar to 43?
I don't understand what does "condering (x,0,0)or (0,y,0) mean.
see photo 2.
I only know how to do 43
I have no idea for 45
  • Textbook page with four limit problems: 43 and 44 use substitution y = mx, and 45 and 46 ask to show limits do not exist along coordinate axes; problem 45 is lim of (x+y+z)/(x^2+y^2+z^2) as (x,y,z) approaches (0,0,0).
  • Handwritten working on lined paper: step 43 substitutes y = mx into f(x, mx) = (x^2 - m^2x^2)/(x^2 + m^2x^2), simplified to (1 - m^2)/(1 + m^2). Step 45 begins with the same substitution y = mx and nothing further.
For a limit to exist, you can't get different answers depending on the direction you approach a point. When the problem says to consider points of the form (x,0,0), it's asking you to calculate the limit as you approach the origin along the x-axis.
BTW: What do you conclude about #43?
For 45 try this
[tex]f(x,y,z) = \frac{x + y + z}{x^2 + y^2 + z^2}[/tex]
What happens when you cut with x = x and with y,z =0? What happens to f?
flyingpig said:
For 45 try this
It becomes [itex]\frac{1}{x}[/itex]
Then, as x[itex]\rightarrow[/itex]0, [itex]f(x,y,z)[/itex] doesn't exist?
It seems if we have denominator, then the function is not continuous at origin.
? The problem does not ask about continuity, only about the limit at the point. It is possible for the denominator of a fraction to go to 0 and the limit still exist at that point.
In problem 43,
[tex]\lim_{(x,y)\to (0,0)}\frac{x^2- y^2}{x^2+ y^2}[/tex]
if we take y= mx, as suggested, we get
[tex]\frac{x^2- m^2x^2}{x^2+m^2x^2}= \frac{x^2(1- m^2)}{x^2(1+ m^2)}= \frac{1- m^2}{1+ m^2}[/tex]
as long as x is not 0.
If the limit exists, then the limit of that should be the same for all m. Is it?
It seems we use the similar method to prove continunity. If not, how do I prove that problem 43 continuous at (0,0)?
