Substitution Rule for Infinite Limits of Integration
The discussion focuses on the validity of using the substitution rule for infinite limits of integration, specifically with the integral of exp(-t^4). The substitution x = t^2 leads to confusion about the new limits of integration, which both approach infinity. Participants highlight that the substitution dx = 2t dt complicates the integral, particularly when considering negative values of t. It is suggested that breaking the integral into parts for t < 0 and t > 0 may clarify the issue. Ultimately, the problem arises because the substitution t^2 = x does not uniquely define t, as it can be both positive and negative.
ehrenfest
[SOLVED] limits of integration
I want to substitute x=t^2 in \int_{-\infty}^{\infty}{\exp(-t^4)} dt. What are the new limits of integration? They are both infinity aren't they? But the integral is clearly not zero? Is the problem that the substitution rule only holds for finite limits of integration?
The substitution introduces dx = 2t dt within the integral. Perhaps a polar coordinate form would be helpful.
Of course, but 2t = 2 \sqrt{x}. Why is this not valid:
\int_{-\infty}^{\infty}\exp(-t^4)dt = \int_{\infty}^{\infty}\exp(-x^2)dx/(2\sqrt{x})
Well, you need to use -\sqrt{-x} where x&lt;0.
Maybe you should break the integral up into the part over t < 0 and t > 0. What does that turn into? I don't know the answer, just a suggestion.
I don't care how to evaluate the specific integral. My question is about the substitution rule. No one has yet explained to me why this
is not a valid use of the substitution rule?
I think it's just because t^2 = x doesn't necessarily imply that t = sqrt(x).
  • · Replies 16 ·
