Limits - Prove that xsin1/x approaches 0 near 0
  • Thread starter Thread starter Miike012
    Limits
The discussion focuses on proving that the limit of \( x \sin(1/x) \) approaches 0 as \( x \) approaches 0. Participants reference the Squeeze Theorem and the epsilon-delta definition of limits to establish that for any \( \epsilon > 0 \), if \( |x| < \epsilon \), then \( |x \sin(1/x)| < \epsilon \). Additionally, they explore the limit of \( x^2 \sin(1/x) \) and confirm that it also approaches 0 under similar conditions. The conversation highlights the importance of understanding the relationship between \( |x| \) and \( \epsilon \) in limit proofs.
  • Epsilon-delta definition of limits
  • Squeeze Theorem
  • Basic properties of trigonometric functions
  • Understanding of limits in calculus
  • Study the Squeeze Theorem in detail
  • Practice epsilon-delta proofs with various functions
  • Explore the power series expansion of trigonometric functions
  • Learn about uniform continuity and its implications in limit proofs
Students and educators in calculus, particularly those focusing on limits and continuity, as well as anyone looking to strengthen their understanding of epsilon-delta proofs and the Squeeze Theorem.
Miike012
limits -- Prove that xsin1/x approaches 0 near 0
Prove that xsin1/x approaches 0 near 0.
similar Proof from book
|sin1/x| ≤ 1
| xsin1/x | ≤ |x| for all x not equal to 0, so we can make |xsin1/x|< ε by requiring that |x| < ε and not equal to 0.
MY QUESTION: Prove x2sin1/x approaches 0 near 0.
According to the book, if ε>0, to ensure that |x2sin1/x |< ε we need only require that |x| < ε and not equal to 0.
shouldnt |x| be less that √ε? Hence |x2 | < ε and |x|< √ε.
Use the Pinching theorem.
-x \le x\sin \frac{1}{x} \le x
Ok how does that tell me that |x2sin1/x|< ε for |x|< ε??
|sin1/x| ≤ 1
Are you supposed to use a δ - ε proof, or can you use such things as the "squeeze theorem" ?
delta epsilon proof
Miike012 said:
Prove that x^2sin1/x approaches 0 near 0.
all I am doing is quoting from the book... and I want to know how they decided that |x|<ε
Well, for small enough \epsilon, 0&lt;\epsilon &lt; \sqrt{\epsilon}.
In fact, we only need 0&lt;\epsilon&lt;1 for this to be true.
Oh and also for a more fundamental reason. In Spivak's book, (I don't know for other books) the proof that this limit is 0 using delta-epsilon comes before the proof that every positive number has a square root (which requires the least upper bound property). So the existence of such a number \sqrt{\epsilon}. cannot be assumed.
This is a common hangup for people doing ##\epsilon-\delta## proofs for the first time.
You don't need to find the "best" ##\delta##; you just need to find one that works.
If \displaystyle |x| &lt; 1\,,\ \text{ then (multiplying by }|x| \text{ gives } |x^2|&lt;|x|\,,\text{ and } |x| &lt; 1\, \text{ ) } |x^2|&lt;1 \ .
So let δ = min(1,√ε) .
There is a general theorem:
If f(x) \rightarrow 0, \ x \rightarrow a, and \vert g(x) \vert \le M, \ \forall x \in U(a), where U(a) is some neighborhood of the point a, then:
<br /> \mathrm{\lim}_{x \rightarrow a} f(x) \, g(x) = 0<br />
Can you prove it?
I just learned the δε definition myself and am very shaky on it. Since |x|< δ can we not turn |x2sin(\frac{1}{x})|< ε into |x|<\frac{ε}{xsin(\frac{1}{x})}. And now we have our δ=\frac{ε}{xsin(\frac{1}{x})} and use this in the proof.
Because it's part of the εδ definition that |x2sin(1/x)|<ε and it's just the nature of the function that |x| ≤ |xsin(1/x)|
No, this way our δ would depend on x.
The ε-δ definition tells us that "For all ε, there must exist a δ, such that for all x, ...". This means that our δ must work for all x. Your proposed δ does not work for all x.
For 0&lt; \epsilon&lt; 1, \epsilon&lt; \sqrt{\epsilon} so "&lt;\epsilon" is sufficient.
You've got your quantifiers mixed up an have given the definition of uniform continuity.
No, I didn't...
Uniform continuity would be "Forall ε>0, there is a δ>0, such that for all x,y..."
Here, I'm holding 0 fixed and I say " "Forall ε>0, there is a δ>0, such that for all x..."
OK, it might be confusing though that I did not write the definition fully.
I must have had a brain cramp!
It looks like you could use either of the following for δ :
δ = √ε
δ = min(1, ε)​
micromass said:
No, I didn't...
Yes. You are correct. I misread your yada-yada. Though I probably shouldn't have given the context.
My bad.
If you want to be fancy, the power series expansion of sinx is:
sinx = x - x3/6 + ...
It follows that sin(1/x) = 1/x - (1/x)3/6 + ...
and x2sin(1/x) = x - (1/x)/6 + ...
so, lim x -> ∞ x2sin(1/x) = 0
