Limits to infinity with natural logs
The discussion revolves around calculating limits involving natural logarithms as x approaches infinity. The first limit, lim ((lnx)^5)/(x), requires the application of L'Hôpital's rule or rewriting the expression to simplify it. The second limit, lim (14lnx^2)/(6lnx^3), initially appears incorrect but can be simplified using logarithmic properties. Participants emphasize the importance of recognizing indeterminate forms like 0/0 and suggest rewriting expressions for clarity. Ultimately, the correct limits can be determined through proper application of calculus techniques.
Cacophony
I'm having trouble calculating these limits.
none
1. lim...((lnx)^5)/(x)=
x->infinity
(((lnx)^5)/x)/(x/x)=
(((lnx)^5)/x)/1=
How do I calculate from here?
2.lim ...(14lnx^2)/(6lnx^3)=
x->infinity
((14lnx^2)/(x^3))/((6lnx^3)/(x^3))=
((14lnx)/(x))/(6lnx)=
0/6lnx= 0
Is this right or am I forgetting something?
use Lhospital
none
x->infinity
(((lnx)^5)/x)/1=
You're going in circles... back to what you started with.
As Punky said, use L'Hôpital's rule.
x->infinity
0/6lnx= 0
In #2, what you have done is incorrect.
Use properties of logarithms for #2. It works out quite simply.
\log_{\,b}(x^a)=(a)\log_{\,b}(x)\,.
I'm not allowed to use L'Hopital, and I will change #2
So would the second problem look something like this:
28lnx/18lnx?
28lnx/18lnx?
If you mean the limit of 28lnx/(18lnx), then yes, that's right.
I'll think about #1 some more. Maybe someone else will help.
ok so it will be ((28lnx)/x)/((18lnx)/x) = 0/0 = DNE?
A limit of the form 0/0 is indeterminate. It might exist or might not exist.
Why are you bothering to multiply the numerator & denominator by 1/x ? (That accomplishes nothing!)
What is \displaystyle \frac{\ln(x)}{\ln(x)}\, for any x in the domain of the natural log ?
1/1 ?
For #1.
Do you know \displaystyle \lim_{x\to\infty} \frac{\ln(x)}{x}\ ?
If so then rewrite \displaystyle \frac{(\ln(x))^5}{x}\ \text{ as }\ \frac{(\ln(x))^5}{x^5}\ x^4\ .
Cacophony said:
1/1 ?
Yes !
What does that leave you with?
So basically the limit is then 28/18?
Yes.
I think I know how to do the first one by applying the chain rule:
limit to infinity
((lnx)^5)/(x)=
(5(lnx)^4)*(1/x)/(x)=
5(lnx)^4*0/(x)= 0
Is that valid?
Ignore my last post I got confused, this isn't a derivative
Look at post #10 .
