How Do You Determine Lines of Maxima and Minima Based on Gradient?
To determine lines of maxima and minima based on gradient, the line of maxima corresponds to the greatest gradient, while the line of minima relates to the smallest gradient. In this discussion, it is clarified that when gradients are negative, the line with the least steepness (most flat) represents the line of maxima. However, it is emphasized that one should consider the absolute values of the gradients. Ultimately, the line with the greatest absolute value of gradient is identified as the bottom line, which is concluded to be the line of maxima. Understanding these concepts is crucial for accurately identifying maxima and minima in graphical representations.
385sk117
Please look at the attached picture
In that I had to draw the line of maxima and minima
line of maxima has greatest gradient
line of minima has smallest gradient
which line should be the maxima? the line with the greatest gradient right?
and as the gradient of the lines are negative here, the most flat line will be the line of maxima? or i have to look at the absolute values of gradient?
The line of maxima should be the one with the greatest absolute value of gradient. In this case, the line with the greatest absolute value of gradient is the bottom line. Therefore, the bottom line should be the line of maxima.
11K
