Line tension problem help
7 replies · 4K views · last reply
drkidd22
I need help trying to figure this problem out.
  • Diagram of a 30 ft pole AC fixed at ball-and-socket point A on the ground, with a 1680 lb horizontal force at top C; cables run from point B on the pole to ground points D and E, with dimensions 18 ft, 18 ft, 21 ft and 30 ft labeled.
Hi drkidd22! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
So I have this so far trying to find Tbd.
It will be the same for Tbe as they are the same distance away from A.
distance on horizontal=√(18^2+18^2)=18*√2 ft
distance on vertical=21 ft
∴θ=angle in between pole & cable=tan-1(18*√2/21)=50.479 degree
Σall horizontal force=0
1680=2T sinθ
∴T=1088.944 lb
Σall vertical force =0
R=2T cosθ [R= reaction force at A ]
∴R=1385.924 lb
Not sure if it's correct
How many components are there to the reaction at A (at most)? You ask if it is correct. But you could determine this yourself by recognising that there are at most 6 equilibrium equations for the whole thing...
So have you calculated any of them so far?
(By the way your physicsp148.doc document has just one line and it is sloppy, or incorrect or inconsistent. If T is a force, why do the units have ft at the end?)
when you say "1680=2T sinθ ", exactly what free body diagram are you considering the equilibrium of?
