Linear algebra, basis, diagonal matrix
7 replies · 3K views
fluidistic
Write the A matrix and the x vector into a basis in which A is diagonal.
[itex]A=\begin{pmatrix} 0&-i&0&0&0 \\ i&0&0&0&0 \\ 0&0&3&0&0 \\ 0&0&0&1&-i \\ 0&0&0&i&-1 \end{pmatrix}[/itex].
[itex]x=\begin{pmatrix} 1 \\ a \\ i \\ b \\ -1 \end{pmatrix}[/itex].
A=P^(-1)A'P.
I found out the eigenvalues (spectra in fact) to be [itex]\sigma (A) = \{ -1,0,0,1,3 \}[/itex].
I'm happy they told me A is diagonalizable; so I can avoid finding the Jordan form of A.
So I know how is A'. I think that in order to find P, I must find the eigenvectors associated with each eigenvalues. P would be the matrix whose columns are the eigenvectors encountered. So with [itex]\lambda = -1[/itex], I found [itex]v_1=\begin{pmatrix} -i \\ i \\ 3 \\ 4-i \\ i+1 \end{pmatrix}[/itex]. But for [itex]\lambda =0[/itex] I reach the null vector as eigenvector, which I know is impossible.
Am I doing something wrong?
Hi fluidistic! :smile:
What you're doing is right.
But for lambda=0 you can still find a vector that is not the null vector.
Actually there should be 2 linearly independent eigenvectors.
They span the kernel of A.
Ah true, I had made an arithmetic error. If there was no 2 l.i. eigenvectors for lambda=0 then the matrix A wouldn't be diagonalizable.
The basis I found is [itex]P=B=\begin{pmatrix} 1&0&0&-i&0 \\ -i&0&0&i&0 \\ 0&0&0&3&-1 \\ 0&-i&-i&4-i&1 \\ 0&1&5&1+i& \frac{3}{5} \end{pmatrix}[/itex].
What they ask for is [itex]A'=BAB^{-1}[/itex] which is (should be if I didn't make any error) just a diagonal matrix whose entries are the eigenvalues I found. And x'=Bx.
Am I right?
also not required, but couple of extra tips:
- As A is close to diagonal, so you can shortcut and find the eigenvalues & eigenvectors for the 3 small blocks that make up A. These will be eigenvectors of A with zeroes in the other entries and will lead to simpler eigenvectors than the ones you have.
- It always good to check by multiplying the matrix by the eigenvector you found and in fact I I think you need to do that. The eigenvectors you have don't look right at glance
- If all your eigenvectors all turn out to be orthogonal, and you normalise, then finding the inverse of P is simple - its the transpose conjugate (P is unitary).
- I think A is a normal matrix (A*A=AA*), if so it guarantees all eignespaces correponding to single eignevalues are orthogonal
I like Serena said:
Note that A=A* (A is equal to its conjugate transpose).
The so called spectral theorem tells us that this means that A is diagonalizable.
So A is actually a hermitian matrix which guarantees real eigenvalues and diagonalisability
hermitian matricies are also a subset of normal matricies, which gurantees diagonalisability by a unitary matrix
I'll second lanedance's recommendation to check your eigenvectors. You should be able to see by inspection that (0, 0, 1, 0, 0) is an eigenvector of A.
I also found different eigenvalues for A, namely ±1, ±√2, and 3, so you should recheck that calculation first.
