Linear Algebra: Image, Kernel and Basis
The discussion focuses on finding the image and kernel of a given matrix A. The image is described as the span of linearly independent vectors from A, and the kernel is identified as the set of vectors that produce the zero vector when multiplied by A. The kernel is confirmed to be synonymous with the null space, and both are subspaces of R3. The user successfully reduces A to its row echelon form and derives equations but struggles with identifying free variables and expressing the kernel correctly. Ultimately, the kernel is found to be spanned by the vector [-2, 1, 0], which serves as its basis.
tangibleLime
I've been browsing the Internet but can't find a straightforward explanation for a procedure on how to find the image and kernel of a matrix.
Question: Find a basis of the image of A, and a basis of the kernel of A.
\[<br /> A =<br /> \left[ {\begin{array}{ccc}<br /> 1 &amp; 2 &amp; 1 \\<br /> 1 &amp; 2 &amp; 2 \\<br /> 1 &amp; 2 &amp; 3 \\<br /> \end{array} } \right]<br /> \]
I think that the image (Googling doesn't help much for some reason... is there another, more popular term for 'image'?) is just the span of vectors of A that are linearly independent; that is, no two vectors can be combined to create another vector in the span (or is it only the vectors that came before it?).
So just by eyeballing it, I can tell that the image of A is [1,1,1] and [1,2,3] since [2,2,2] can be expressed as 2*[1,1,1]. But what if this matrix was more complicated and I couldn't eyeball it? From reading the definition, I think a basis of the image is just the entire span of the image... since by definition, the image already contains no redundant vectors.
I think that the kernel (or is it null-space? Are those terms synonymous?) is the span of vectors that, when multiplied by the matrix, result in the zero vector. Therefore, the kernel would always be PART of the image, but not necessarily the entire span of the image... correct?
So to find the kernel of A, I took A and put it into RREF, eventually resulting in:
\[\left[ {\begin{array}{ccc}<br /> 1 &amp; 2 &amp; 0 \\<br /> 0 &amp; 0 &amp; 1 \\<br /> 0 &amp; 0 &amp; 0 \\<br /> \end{array} } \right]<br /> \]
Translating this to a set of equations gives me:
x_{1} + 2x_{2} = 0
x_{3} = 0
But I'm not sure what to do from there. There are no free variables like there usually are when I solve a problem like this. I tried to do this, but now it looks weird and I know it's wrong:
x_{1} = -2x_{2}
x_{2} = \frac{1}{2}x_{1}
x_{3} = 0
I do know (thanks to a calculator) that the kernel of A is [-2,1,0], but I don't know how to get that manually.
Anyways, assuming I do know how to get the kernel of that matrix, I need to find the basis of the kernel. My understanding of basis is that it is simply the span of a vector space with linearly independent vectors. Since kernel is a vector space (right?) the basis of it would simply be the span of linearly independent vectors that make up the kernel. In this case, there is only one vector... so that is the basis?
Any help would be greatly appreciated.
The image of A is the set of vectors y such that Ax = y. IOW, the image is the set of outputs.
Yes, that's right. And the terms nullspace and kernel are synonyms.
Right. Also, the kernel and image are subspaces of, in this case, R3. Further, dim(ker) + dim(image) = dim(R3) = 3.
x_{1} + 2x_{2} = 0
x_{3} = 0
x_{1} = -2x_{2}
x_{3} = 0
A good start.
x_{1} = -2x_{2}
x_{2} = x_2
x_{3} = 0
So there is one free variable, x2. Another way to write these equations is more vector-like.
\left[ \begin{array}{c}<br /> x_1 \\ x_2 \\x_3 \end{array} \right]<br /> = x_2\left[ \begin{array}{c}<br /> -2 \\ 1 \\0 \end{array} \right]<br />
This expresses any vector in the kernel of A as a multiple of the vector shown.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
15K
