Linear Algebra Matrix Eigenvalues
8 replies · 2K views · last reply
lina29
The matrix A has 3 distinct eigenvalues t1< t2< t3. Let vi be the unique eigenvector associated to ti with a 1 as its first nonzero component. Let
D= [t1 0 0
0 t2 0
0 0 t3]
and P= [v1|v2|v3] so that the ith column of P is the eigenvector vi associated to ti
A=
7 2 -8
0 1 0
4 2 -5
a) Find D
b) Find P
c) Find P-1
My thought to find D was to find the characteristic equation of A which I found to be (t-3)(t+1)=0 so the eigenvalues would be t=-3, t=1 I then plugged in these values into the matrix D so D became
3 0 0
0 -1 0
0 0 0
but it was counting it wrong. What did I mess up on?
Hi lina29 :smile:
I'm afraid your characteristic equation is a little off.
How did you get it?
And your eigenvalues are not the solution of the equation you have.
They are off by a minus sign.
You're supposed to get 3 distinct eigenvalues.
(They should be 3, -1, 1.)
Oh, and according to your problem statement your eigenvalues should be sorted low to high on your diagonal.
To find the determinant I did aei+bfg+cdh-ceg-bdi-afh. So I got (t-7)(t-1)(t+5)+0+0-(8)(t-1)(-4)-0-0. I simplified that to (t-7)(t-1)(t+5)-(-32)(t-1). My mistake was that I accidently crossed out the t-1 on both sides. From there how would I get to P?
Good! :smile:Find the eigenvectors v1, v2, v3.
P is the matrix with these eigenvectors as columns.
So the eigenvectors would be -1, 1, and 3. Then the matrix P would be
-1
is that it?
or I guess that wouldn't be right since I need to find P inverse so P would have to be a square matrix
-1
is that it?
No. There's a difference between eigenvalues and eigenvectors.
t1=-1 is your first eigenvalue.
v1 is the vector belonging to this eigenvalue.
To find v1 you need to solve A v1 = t1 v1.
Note that any scalar multiple of v1 also satisfies the equation, but its direction is unique.Edit: I just saw that your problem statement says that v1 should have "1 as its first nonzero component".
